Hi, i am still quite new to watch repair, but got my hands on a beatiful Omega Seamaster.
When i got it a year ago, i took it to a jeweler, because i wasnt working, he just told me it wasn't worth fixing. unless it had sentimental value.
Then finally i have been learning and repairing some mechanical movements, but as this is a quartz, i am abit lost. The watch runs and keeps time after i took some of it apart and put it back together, but when i wear it, after like 1 hour or something maybe less, it stops. Does it just need to be cleaned and lubricated again. or could it be the stepper motor, i couldn't really find out if it could run with a Stepper motor that isn't working properly.  i have also noticed that there is no movement clamps holding it in place, could that also cause the problem, when the back is on, it doesnt seem to move or anything.
I expect it does just need a good clean and service.
Can you confirm what battery you've fitted?
Edit
Case clamps shouldn't make a difference but would be advisable to get some if you get it working.
Edited by AndyGSi
Thanks Andy, i was also just expencting a good service, it just supriced me as a "Watchmaker" told me it was not worth fixing, if its just a service. Maybe he is just not very qualified. as i assumed he was. Richard, here you go i had 2 pictures af the front 🙂
It probably the fact that not a lot of 'watchmakers' work on quartz or it
maybe because of what he'd charge for a service it wouldn't be worth it.
As I side note, the dial doesn't look right to me, what's the details on the case?
I would fix it if it were mine.  Early jeweled quartz watches are cool, and it is an omega.
My first guess would be there is an issue with electrical contact.  Make sure all of the screws in the electrical path are making good contact.  Check to see that the battery contacts are clean.
After it stops, can you start it by just jiggling it around?
Except for the calendar works, this looks like an easy service, but you should not attempt it until you develop your skills.
    • One of the problems we would have with a watchmaker's lathe is they were made over considerable span of time and manufacturing in the early days probably wasn't as good as it was today. Then if you look at the older catalogs typically it was just the head a few collets and something to rest graver on. So basically a basic lathe with over time things acquired but acquired things may or may not fit. Order today you purchase a used lathe that all kinds of nifty bits and pieces from a seller that acquired from? This would come back to that the basic watchmaker's lathe was used for basic watchmaking like turning things with a hand graver. Then limited indexing is fine because you can make things like stems Which don't need a whole bunch indexing   In the link above the word vector is mentioned and at the link below you can purchase one. Then of course you're going to need the motor that's a little bit extra for the price. https://www.hswalsh.com/product/lathe-vector-watchmakers-48-collets-hl11. That you're going to need some bonus parts like these found this picture online show the classic way of classic gear cutting.   The lathe could have a much bigger indexing disk but it has to be mounted close to the edge. Otherwise you're going to have a whole bunch of smaller disks like this which I think has notches rather than holes. Then as wonderful as these pictures look actually cutting a gear with this is not entirely fun. Look at all is belts all pulling on things and this is a watchmaker's lathe lightweight with lots of bits and pieces attached. It would make more sense if you actually cut a gear with something like this and it tends to be it's not really the best way to do it looks nice on paper but it is not the best way to go. Reality for cutting watch parts would be a bigger machine is much better. Than getting rid of all those belts and pulleys also good. Here is an interesting channel I would've liked of found a different video but this was nice and short if you look at his video as he uses a stepping motor and worm gear assembly for the indexing plate. In this particular video it gets attached to the lathe at about one minute and seven seconds and it looks like it's hiding looks like he has a Sherline. I do know he's had other stuff you'll just have to go through his videos to find it. Then at about one minute and 22 seconds you find out if you set up things appropriately. It's always bad we end up with half a tooth at the very end. Then you will note big lathe yes he's getting a big gear but you could easily cut a watch gear with the setup. And it definitely way more stable than a watchmaker's lathe.         Oh here's a company they been in business since 1911 http://www.fwderbyshireinc.com/
