14 hours ago, ManSkirtBrew said:
Same here, but it fouls on the inside of the crystal, so I'm assuming it should be a little deeper.
Looking at Stian's video, it does seem like it should go on a bit further, but his also springs in the same as mine, so maybe not?
image.png.400e97110d6ca1f470f833180fb8bcd6.png image.png.fe3e545e4a1d3ed523884d714e7e7f45.png
Yes, just as in the video, with the retaining spring sitting on the sloped shoulder of the seconds arbor.
Okay, I adjusted the hands a bit and everything seems okay now. It sets a lot more easily than I'd expect, but I'm hoping that's just how this movement is. It's running in now.
You need a holder with the center support. Doesn't have to be Bergeon and some are available by 3d printing. The screw on the bottom and hole on the sides are to see that the adjustment is correct. I think I bought mine specifically for the 1001.  Hand setting holder.or something like that.20240819_0654472.thumb.jpg.71b5235ed89f05fe5f289e75d4ecb261.jpg20240819_0655032.thumb.jpg.ce8d9f6f13851e0269cbc49389e0a60c.jpg
you can also do this on a staking tool. although its a bit cumbersome. You use a stump to support the back of the seconds pinion. I'm in the process of making a stake that is threaded to accept different tips to press the hands on.
If it's not the Canon pinion it could be something with the minute wheel pinion for why the minute hand is not moving but the hour hand does. Here is a dial side shot without the calendar works on my dirty 1001 (later cleaned up) if that helps.DSCN57232.thumb.JPG.7b2a165423f27c56dde84da3d9a1be5c.JPG
So Stian is wrong in saying the automatic module bridge will hold the center seconds pinion in place?
Thanks, @JohnR725, that makes sense with regard to the bushing.
Those instructions then imply the hands must be fitted before installing the automatic bridge, otherwise there's no way to support the seconds pinion.
Now I've just got to find a movement holder.
I would err on the side of caution and use the holder. Yes. And the convention is to remove and add the automatic works while the movement is in the case, so yes put the hands on, Case the movement and then put the automatic works on if you can. My case for my 1001 doesn't work that way so I have to add the autoworks on before casing. I think this is one of the reasons this movement gets a bad rap from watchmakers, the awkwardness of the casing.
Edited by Razz
Those instructions
Yes one of the unfortunate problems and watch repair is missing technical information. With the early days stuff was scanned solely for parts and they deliberately skipped over anything technical like servicing. Then we have some companies putting stuff in separate documents which of course had nothing to do with parts so they never were scanned. Then today where they don't want to share the documentation at all. Which makes doing a watch like this extremely problematic if you don't have the supplemental information.
Are the centre screws interchangeable between sizes?
The Chinese jewel press kit I got has a set of movement holders, though only up to 11 1/2 ligne.
It's less than two of the branded holders. You could use one of the centre screws in the larger cheap holder?
£82 for a reasonable jewel press with holders and hand fitting tips..
https://www.aliexpress.com/item/1005005982837074.html
Cousins UK has the Bergeon 12.5 ligne #M0981 for £46.75. There might be a less expensive option.
Hey thanks! I don't think the Rolex ones will work because the screw is too blunt. That pinion is recessed pretty well in the movement.
However, as I'm here in the states, Esslinger has a version of that Bergeon holder available, which looks like it'll work. Interestingly the same part number as the Bergeon.
Make sure you get the 12.5 ligne for the 1001 movement!
Coincidentally, £46.75 converts to $60.95 right now, so I'm okay with that price. It's on its way to me right now.
Okay, the problem was the center cannon being too loose on the wheel. I didn't have a cannon tightener, so I ground two broken stakes on my little belt sander, then stoned them.
I didn't have a rod that fit inside perfectly, so I had to just be extra gentle with my tapping. After a couple taps, it popped right on with a good amount of friction.
That's as much stress as I have in me tonight, so it's red wine time until I find another free hour.
Nicely done msb, accurate grinding of your stakes 👍
Did you also broach it out to size with a mini lightsaber at the same time ? It takes a lot to impress me , but you achieved it matey.......Very Cool indeed 😁
  • Haha 2
Hah! Sadly, no. My mini lightsaber is in the shop.
I did realize I wouldn't be able to broach it, so I was very gentle and got lucky on the first try.
This is one of those times where you shouldn't trust the aliexpress copy and buy Swiss if you want to keep your fingers & eyebrows.
  • Haha 2
Well you must have two then, i can see one poking the cp in your photo 🙂
It matches the two brain cells I have to rub together, apparently 😁 I'm a little dense these days.
I wondered what the light sabre comment was until i looked at the photo again. Hehe.
I got to be very tired to miss the opportunity for making sarky comment 😁
Aren't we all sunshine.....aren't we all 🙂
Love the integrated bracelet and round dial. I found an advertisement from the time period somewhere touting the high beat and the first of its kind integrated bracelet of this watch. I have the square dial version and the case has 4 screws and much harder to do simple rate adjustments without taking it completely out of the case.
Edited by Razz
    • After cleaning up the pivots, I made bushes on the lathe. At this point I've pressed in 6 bushes (3 sets) and the wheels turn smooth. What I can also tell you, is that I'm not looking forward to final assembly. Getting the pivots aligned seems to get exponentially more difficult with each wheel that is added.
    • Islands are interesting places to live depending upon their size and other factors. This is a bigger island and it has a bridge to get there at least on one end. It's also big enough that you don't have to go someplace else to get things typically. It can be a problem if you get a job in Seattle though. Yes I've known of people who commuted from the island to Seattle for a job and I don't quite remember how many hours it took but it took a long time. So basically islands are nice if you don't have to leave very often.
    • Thanks @JohnR725! Everything you say makes a lot of sense and is encouraging to read.
    • isn't it nice to have a decent case open or when the case doesn't want to be opened? In the case of a Rolex watch that supposed to pass specific water resistant testing you probably do need to tighten the back down. But they shouldn't be tightened so much that they risk stripping the threads out. Then the other problem that comes up is the gaskets can start to disintegrate and then getting the back off can be quite a challenge unless you have a really good tool and perhaps some penetrating oil to loosen things up. Yes really nice case marking. When I was in school we were taught to mark the cases and  the American watch and clockmakers Institute even had a? So if you joined at one time they would give you an identification number. They were explaining or giving an example of if the watches ever found in you have a unique number they can perhaps figure out the history of the watch or identify the body it's attached to for instance not that that probably comes up that often. So you got a unique number and even made a special metal stamp that you can purchase. It wasn't a super big aggressive stamp but still it left a mark in the back of the case. Then I heard from people at work on Rolex watches they were using a felt pen indelible but later on they decided that was bad because apparently the ink could release  chemicals although it seems like once it's dry that shouldn't be an issue. Then of course today was nice is you can keep computer records sealed have to mark anything at all I personally find it's best to leave no reference behind that you were even there. Especially when you have a beautiful watch that has no markings at all and now it has your scribbling all over it not good typically if there is a typical and watch repair?  a lot of minor repairs you don't need to do a complete servicing. But beyond a certain point you're going to have to take apart a lot of stuff you're going to disrupt the lubrication even if it looks perfect right now and yes you might as well just go ahead the service the whole thing. also in a watch like this where a lot of things seem to be going on the complete service would be better then you'll know exactly where you stand versus dealing with unknown mysteries for prior repair.
    • That Island looks pretty good on the pics I found. Must be nice to live there. Welcome! Are there many watchmakers over there?
