Hello all,
I recently bought a second-hand Bergeon 5285-D staking tool in pretty bad but repairable shape. One thing missing on it was the circular rotating anvil. I have ordered one of those from cousins, but what's still missing is the bolt/screw sitting in the centre hole of the anvil (see pic below). Bergeon does not seem to sell these bolts/screws as spare parts.
So my question becomes: is there anobody with a Bergeon 5285-X who could provide measurements of this part? My goal would be to make a CAD drawing of it and put it up on e.g. thingiverse and/or shapeways with an open license, plus post in the the 3d print subforum here of course... 🙂
As far as I can tell, the measurements I would need are:
1) the diameter and height of the head (top) part
2) the diameter and height of the body part
3) the position on the body where the centre of indentation for the fixing screw sits.
And ideally, also a pic that shows the shape/angle of the indentation.
I would be deeply grateful for any help provided. Many thanks in advance, /Lesuedois
    • Yes, the specific old tools do exist, but may be having one is not needed as they are not cheap, and also You will be able to do without it well enough. My advice will be to use regular depthing tool and adjust it for the exact distance between pallet fork and escape wheel bearings from the watch. Then remove the shellac from the pallet that now doesn't pass the ew teeth and move this pallet in. Then put the pallet fork and ew on the depthing tool and check how they lock. They should not lock when the pallet is in, but You will little by little move the pallet out and locking will appear. Then move just an idea out for reliable work and apply shellac, then check if things are still the same. You have to observe where the teeth fall on the pallets - it must be just a little below the edge between impulse and rest planes. Then You must check how everything behaves in the movement This Potence tool is so ingenious, but actually, the traditional way to do the things is much more simple. Arrange the parts not on the pillar plate, but on the cover plate. Only the central wheel will remain on the pillar plate, secured by the cannon pinion.
    • There is a tool that was made for setting up and adjusting escapements of full plate watches.  There were two styles, the picture below shows both of them.  The lower tool held a movement plate and the vertical pointed rods were adjusted to hold the unsupported pivots of the lever and escape wheel.  There was also a version of this tool that had 3 adjustable safety centres so that the balance pivot could be supported by the tool :  The other version I’m aware of is the Boynton’s Escapement Matching and Examining Tool came as a set of two or three clamps that gripped the watch plate and held the safety centres for the pivots : These do turn up on eBay from time to time.  For some escapement work, you can set up the parts in a regular depthing tool, with the centres set according to the distance between the corresponding pivot holes on the movement.  I hope this helps, Mark
    • Once you are aware of the problem, you can adjust as necessary. I have a couple of the Omega 10xx, and they are not my favourites. They seem a bit flimsy and not as solid as previous generation Omega. But I think that's true of a lot of movements from the 70-80s. For me, the 50-60s is the peak in watch movements, where the design criteria was quality, not saving the last penny.
