Have a question I'm servicing a
ETA 956.042 movement a know I'm not meant to clean is individual parts in my cleaning solution but is there a way to make them clean a bit with
You should be OK to wash the circuit board with high purity isopropyl alcohol (not the 70% stuff). IPA is commonly used in electronics manufacture and repairs and is safe on most such materials.
Use a soft paintbrush if needed to remove any stuck dirt or flux, keeping it wet with the IPA.
Then dry it somewhere warm to avoid condensation as it evaporates.
I'd treat just the tips of the battery contacts with Deoxit using a cotton bud to apply it; or a very fine trace light oil if you cannot get deoxit. It will help prevent tarnish and maintain good contact with the battery.
For a dial or date ring, I'd not use anything other than deionised water on a cotton bud, with very little pressure, and only if there is no lume.
I'd rather leave them alone if practical.
Yes, that oil should be OK.
Put a very fine trace of it on the contact surfaces that are likely to be in contact with the battery, rather than where they attach to the PCB.
Transfer it via something absorbent rather than putting it on straight from the bottle.
    • You need to know at least the basics. Then the questions that You ask will begin to make sense. From what is seen on the video, the gear train and escapement look fine, but the balance doesn't rotate free. I can suppose that the thin gold colored shim that must stay under the balance cock is not in place.
    • Yes, there are a lot of shapes and all of them are used in different cases. The one in Waltham A11 is one of the most spreaded and is what I have shown in the beginning. Of course, the radius of the final curve will depend on the distance between the hole in the stone and the regulator pins on the cock
    • I just found these. They don't really grab my eye at the moment, but having seen the change in some of the watches on here, before & after, the results have been pretty impressive. https://www.ebay.com.au/itm/196382906131?itmmeta=01HXBSJJXDB5J6H916ARJP9PHE&hash=item2db9555713:g:REwAAOSwUNdmOYAZ&itmprp=enc%3AAQAJAAAAwOAlUO3a1pAUX60Y8gUeXMPriraj5e7rkBNH2EA6cIUH7kb7hzoq6jRmOsYOQazk9R%2FteDESr1e50Asabv2tbJyDM%2FVODtmrAScFS4jPhHdgu6Jvt%2BFuRGBijpTkPl4NiK%2FDGr6qztc1Ujb33Tt6YdaUztOH9R1y9XJbwjH0puPDy8m0ilYcal7Vphcp7d59DLtBliNnbqfxfWhxdia2xMRyHYFHzR0Rg7NqB1z4xQGMZb73MAG4QBiF9FMkrII88Q%3D%3D|tkp%3ABk9SR_KuyvnqYw
    • I agree, it's getting harder and harder to find anything that meets the brief other than complete junk, or fake/frankenwatches. I would be in favor of raising the limit so people can continue to enjoy the challenge of resurrecting these low cost watches to their former glory and allowing the watchmaker the ability of practicing new skills without the worry of breaking the bank if all doesn't go to plan. Now all we need to do is settle on a value - maybe base the value on a standard currency so we are all playing by the same rules ($, £, €...?) Unless anyone minds I could start a poll and we could all vote on currency and value... let me know!
    • Same for me, but this is the first time I use the Bestfit. I understand that, for a 17-3/4 caliber, I have to consult page 150, but I can't find any resemblance. Thank you for all your research. I learn a little more each time I use this forum 😀
