Tag Heuer 2000 - faulty crown or faulty stem ?
Hi everyone,
please bear in mind that this is my first attempt of repair of this type so I might not have the right terminology of things, if so I apologise for that.
i recently acquired this Tag heuer 2000 series 973.006, however for some reason the crown does not push fully inside the case/tube and seems to be locked at the date selection.
In other words, I can’t pop it in as it’s blocked so by moving the crown it is changing the date. If I pop the crown out once it then moves the hands. Which makes me thinking especially looking at the gap between the crown and the case that there is one more step to put it in.
Checked the crown which seems to be the right diameter, could it be due to the stem being too long or unadapted for this movement ? Which direction should I start to fix it up ?
Edited by Jojotime
Pictures missing
On 3/11/2024 at 5:07 PM, Jojotime said:
Hi everyone,
Hi there,
Is the crown 'screw in' type, or 'normal'?
From what You say, I will assume it is normal type. If so, then You would need to do this checks:
Take out the stem with the crown and take out the movement from the case. Then, test
1. If the crown (with the stem) goes on tube/case normally to the end. If not, see if there is some obsticle inside the crown that needs to be cleaned/removed.
2. Put the stem back in movement, but without the case. Check if all functions as it should.
On 3/11/2024 at 3:07 PM, Jojotime said:
Hi everyone,
I've had this before, the gasket in the crown had swelled up probably from someone trying to clean in naptha. Do as Nev suggested, have the movement out of the case and make sure that the gasket will slide over the tube. If that is ok then start looking at the stem for correct length.
it should have a screw-down crown, a picture of the movement would help, should be ETA, the newer replacement movement has a really small pin on the setting lever that holds it in its perspective place, it breaks sometimes but any of these movements could use lubrication in the setting, the o-ring in the crown can be replaced if needed too.....
    • I've bought brands like Citizen, Seiko, Titoni, Tissot, Roamer. Strange thing is many of them were using ST96 movements. I'm not sure if the ST96 is original to that model or whether it was a replacement movement.  All the watches with nice looking dials were obviously refurbished, after-market dials. And all of them had over-polished watchcases. Some of them had non-original hairsprings, rejewelled pallet forks, watch crystals that don't fit and glued in with a generous amount of glue. One of them was totally not working because the pallet jewel was loose to the point that it almost fell off. But the sellers were very nice. The seller of the non-working watch gave me a complete refund. Some of them gave partial refunds. I would say don't by luxury watches on the internet, regardless of the country the seller is from. Don't believe the "serviced by master watchmaker" statement. Have realistic expectations. ( Do expect the occasional complete junk.) Do expect to do a complete overhaul and major repairs. Otherwise, watches from Mumbai are great. For clocks.... I'm not so sure.
    • In 2020,I picked up an Orient Mako II online. It ran at +15 seconds per day and after 3 years of resets more than weekly, it was time to crack the seal and take a shot at regulating it. Not having a timegrapher, I used a spreadsheet to track the time, referenced the Canadian NRC website, wore the watch between adjustments, and used the back end of some tweezers to lightly tap the regulator daily until it ran to within one second per day.   Two months later, it’s still running to within 1 second per day when measured over a week or longer, while daily variations are up to 9 seconds per day. For my purposes, its overall stability is surprisingly good. Is this method of adjustment “better” than adjusting to 5 positions using a timegrapher, since during the adjustment period the watch is already in the environment in which it’ll be used? Rob in Winnipeg
    • Nice file  Just got old pocket watch in and tools,  can I get it back together or should I give up.  we'll see  thanks for the info
    • @HectorLooi Yes, I would say that Mumbai has the highest liquidity in terms used watches. How was your experience with these used watches and what watch brands did you buy used? I have always found the vintage luxury watch segment in India a bit shady. Quite a few are genuine watches with genuine matching parts but just not from the same one.
    • Interesting interpretation of "traditional". I would say that Loctite is definitely the up-to-date and appropriate stuff to use, however, it is a relatively modern solution. Before the advent of such esoteric solutions I believe that the "traditional" thread locker of choice may well have been a sugar solution. Once applied the water would evaporate and the sugar would crystalise, locking the threads tight.
