L&R Master Question: Motor Housing Removal
That is really familiar, wild guess is it's a watch movement 🙃. No i actually recognise it, i use bridge shapes to identify movements and associate the shape with something , this one is mutant elephant( yes thats really a thing i do, believe it or not ) . Its not a bad movement tbf. Take it out of the case, remove the dial and lay it dial side up , we'll talk you through how to identify it properly without behaving like a crazy person 🤪 -
Haha, so you put your big boy pants on 👍😅. Give it a day or so to settle in then regulate it again, will save you opening it back up again after you've worn it. -
By RichardHarris123 · Posted
Have you got the click, it's missing in the photo. -
By HectorLooi · Posted
When you say calendar motion is not working, do you mean the quickset date is not working or when you adjust the time past midnight it is not working? Or both are not working? -
Thanks Richard, I'll give that site a go! This is the movement. It's battered and beat up and will probably never run properly! But I'm using it as a training movement and I'd like to try and at least get it fully assembled.
