Remove a stuck 1.20mm screw from a butterfly clasp
Clickspring as a video review of the chinese demagnetizer.
Hi @Roll1ex, welcome to WRT. Is there a big second hand watch market in Mumbai? I seem to see a lot of used watches and clocks on eBay coming from Mumbai. I used to buy a watch every month from Mumbai on eBay. My mentor told me it was the best way to learn watch repair, by fixing everything that's not right. -
Here is another option, if you have the patience to sort through the parts you usually find 50-100 screws as well as some other cool stuff. Most times I get an order from these guys I get a 250g box, takes a few days, but end up with hundreds of spares and all you need is for one of them to be useful and it pays for itself. Also helps hone your tweezer skills!
As Hector said they have too much tension, that tension is also fixed and not easy to control. Conventional tweezers have infinitely variable grip provided by us. -
Thank you and i appreciate that, it looks very different Thank you sir but i think there is a little problem according to that reading it's because it is far different to the other move that i serviced, i will atouched the photo. They are different movements but this one is 7s26b movement and they are also different in shape when it comes to the ballance assmebly. Thanks also for the concerned i appreciate that.
