I recently purchased an old Elma cleaning machine and received an unexpected accessory with it, besides the basket. I found out it is a movement holder and I also have an approximate idea how it works. The question is, what am I supposed to fit into it? Just the mainplate? Bridges, too?
These are made so that you can clean the entire movement(s) in one go, without taking it apart first, this assumes that the dirt/oil/debris etc  cannot hide in any covered areas, and that you can access all areas after to lubricate etc.. personally speaking I don't think they are very useful for most members on this forum.
They were actually designed for one purpose but now they can have two purposes.
As you noted the watches cleaned entirely assembled if you are following a modern or some modern shops typically with Rolex for instance you will do a pre-cleaned cycle. This is where the watches left together the movement and its cleaned in that condition usually in a slightly shorter cycle the purpose of giving you a nice clean watch to evaluate.
But the real reason for this is it's a faster way to service a watch. At one time they would make a substance it went by the name miracle lube or one step. There were others is also a dual lube method that did the same thing. The basic principle is you clean the watch assembled that saves that pesky time of disassembling. As far as lubrication goes I really like miracle lube as I think the miracle it works But? So I finally got to see a material safety sheets for one of these substances and basically it was mineral oil which is a high-temperature oil in your last rinse. So your watches all nice and clean with no lubrication and the last rinse has the high temperature oil dissolved in the rinse itself so now you have oil covering everything but don't worry the magic of capillary action. As the solvent evaporates the lubrication will migrate to all of the crevices like where the pivots are. So now your watch is 100% lubricated and yes that was the selling point you can increase productivity by quite a huge percentage because you don't have to disassemble a you don't have to do manual lubrication. Obviously there's a reason why this no longer exists but it didn't exist at one time and it was very popular with production shops.
The watch equivalent of fast-food, I can see the attraction, but probably just like the fast food pictures and description which don't live up to the reality.
  • Haha 2
    • Thanks for this post MikePilk, I just came across a similar problem with an Omega 1022.  The problem I had was the seconds pinion spring was bent out of shape and did not even engage with the wheel properly, so the seconds hand was not moving at all. (no power loss though :) I removed the automatic module so I could access the spring and work on it. Once I bent it back close to the right shape, I experienced the same problem you reported about power loss.  Many tweaks later, and the seconds hand is moving properly again, with amplitude back to good numbers again. Cheers
    • After cleaning up the pivots, I made bushes on the lathe. At this point I've pressed in 6 bushes (3 sets) and the wheels turn smooth. What I can also tell you, is that I'm not looking forward to final assembly. Getting the pivots aligned seems to get exponentially more difficult with each wheel that is added.
    • Islands are interesting places to live depending upon their size and other factors. This is a bigger island and it has a bridge to get there at least on one end. It's also big enough that you don't have to go someplace else to get things typically. It can be a problem if you get a job in Seattle though. Yes I've known of people who commuted from the island to Seattle for a job and I don't quite remember how many hours it took but it took a long time. So basically islands are nice if you don't have to leave very often.
    • Thanks @JohnR725! Everything you say makes a lot of sense and is encouraging to read.
    • isn't it nice to have a decent case open or when the case doesn't want to be opened? In the case of a Rolex watch that supposed to pass specific water resistant testing you probably do need to tighten the back down. But they shouldn't be tightened so much that they risk stripping the threads out. Then the other problem that comes up is the gaskets can start to disintegrate and then getting the back off can be quite a challenge unless you have a really good tool and perhaps some penetrating oil to loosen things up. Yes really nice case marking. When I was in school we were taught to mark the cases and  the American watch and clockmakers Institute even had a? So if you joined at one time they would give you an identification number. They were explaining or giving an example of if the watches ever found in you have a unique number they can perhaps figure out the history of the watch or identify the body it's attached to for instance not that that probably comes up that often. So you got a unique number and even made a special metal stamp that you can purchase. It wasn't a super big aggressive stamp but still it left a mark in the back of the case. Then I heard from people at work on Rolex watches they were using a felt pen indelible but later on they decided that was bad because apparently the ink could release  chemicals although it seems like once it's dry that shouldn't be an issue. Then of course today was nice is you can keep computer records sealed have to mark anything at all I personally find it's best to leave no reference behind that you were even there. Especially when you have a beautiful watch that has no markings at all and now it has your scribbling all over it not good typically if there is a typical and watch repair?  a lot of minor repairs you don't need to do a complete servicing. But beyond a certain point you're going to have to take apart a lot of stuff you're going to disrupt the lubrication even if it looks perfect right now and yes you might as well just go ahead the service the whole thing. also in a watch like this where a lot of things seem to be going on the complete service would be better then you'll know exactly where you stand versus dealing with unknown mysteries for prior repair.
