Farer Watches
Yep, I've got the Farer Maze GMT v1 which was a present to myself for my birthday a few years back. I also bought the steel bracelet for it at the same time.
I think it's great, definitely has a good wrist presence and looks and feels premium with combinations of brushed/polished sections, amazing dial, good bezel action. I also really love the tiny bit of bronze in the crown that has slowly developed a patina. I've had no issues with it either (except what I mentioned below).
I did have an issue when it arrived after being shipped to the other side of the world. The GMT hand was out of sync and the movement magnetised (probably happened at some point in transit). Rather than shipping it back at a large cost and time I talked to Farer and then took it to a local watchmaker who sorted it out for me and Farer then reimbursed me. They were extremely quick to respond to me and very friendly and easy to deal with so I have a great impression of their customer service too!
Hope that helps a bit!
    • At some stage you will have to jump in and have a go.
    • Ah so its you thats buying up all the DD calibres 🤨.
    • Hi Richard,  I keep buying CAL.59 movements to practice on 🙂 Not started yet though, I'm gathering tools and building my confidence to start.
    • Problem solved. For some bizarre reason, the hook on the wall of this barrel is not properly centered vertically, but is oddly high on the wall, maybe 3/4 up the way up. When replacing the mainspring, this caused the outer coil to be displaced upwards as well such that it protrudes out of the barrel and caused the barrel lid to not sit quite flush to the barrel. Since this is a motor barrel, the lid is actually the first wheel and inner coil tube/hook all in one piece, with no “snap down” action that would have made the problem more immediately obvious. Maybe with an older mainspring the spring’s end hole was enlarged such that this wasn’t an issue, but hard to say how it ever worked otherwise. Replacing the barrel with one from a different model 1900 where the hook was properly vertically centered allowed the lid to sit flush without mainspring interference and the friction problem went away. The bridge was far too thick to be bent (and isn’t), for those of you thinking that was the problem. Placing the removable arbor in the watch without the rest of the barrel proved that the proper end shake was actually there as long as the overall height of the assembled barrel was correct.
    • You are so true on a lot of what you have said. The main reason for changing the mainspring even if the old one is in good order is because it will take out your thinking that the mainspring is contributing to poor power output or fluctuations in amplitude. If a new spring is fitted that box can be crossed off as a potential source of a problem. Most customers are happy to pay the extra £20 for a new mainspring if they are already parting with a couple of hundred pounds for a service. A new spring is an investment for good running for the future.
