Working on (tiddlywinking away) endstone jewels
the lugs/bezel insert look like Omega Speedmaster, Omega does use screw-down crowns on some models but not sure what you have......I wish you had the back
There is a known fault with the 3135 which is if the watch has not been serviced the Auto rotor can wear. See attached pic.
