Is this safe to use?
4 hours ago, gpraceman said:
I don't see any diodes.  I see one large resistor and a couple of selenium rectifiers.
A rectifier is a diode.
A power LED would be nice, but that would take away from the original look.
I bought a pack of inline switches that have an LED indicator. That is the way to go.
https://www.amazon.com/mankk-Appliance-Control-Indicator-GW320-W/dp/B09B9MBXWP/ref=mp_s_a_1_5?crid=2PC4R7VJU9WHJ&keywords=ac+inline+switch&qid=1703330473&sprefix=ac+inline%2Caps%2C290&sr=8-5
Edited by LittleWatchShop
Ah.  From what I had been reading it does seem like those should be replaced.
The switch sticks in the down position, so that may also get replaced.  Seems just like a two position switch, so a momentary on SPST switch would do.  I see the capacitors rated up to 600V but not sure the voltage that the switch actually sees.
Great idea.  Having that, I could keep the demagnetizer plugged in but switched off.  The visual verification of it on or off, that the LED provides, is nice.
Once the various components are replaced, will it be more effective than a cheap modern demagnetiser?  If not why bother?  Genuine question's, I'm just interested.  I have two demagnetisers, one cheap Chinese one, works OK, one homemade, a central heating pump with the rotor removed, very powerful.
The cost of a new instant demagnetizer is rather expensive.  An Elma unit from Cousins is £207.95.  Even with replacing components on the vintage unit, it should be significantly less cost.  Not sure on the cost of components yet (which should not be a lot), but I only paid $50 for the unit.
Cheap, to rebuild. Far better than the cheap units IMHO.
The big cap is $10. All of the other components total less than $5
I found an Elimag schematic that is pretty close to what I see with this L&R unit.  I made some alterations to it reflect what I see with the L&R.  With the L&R there is an extra capacitor, the 0.05 uF capacitor (the one in my photos that is not all waxy/oily).  Not sure what the purpose of that one is.  There is no 220 Ohm resistor or a resistor for the light.  Though maybe the light has some internal resistor.
It looks like I made a mistake on the switch.  It is a SPDT.
    • You definitely pick up different names from different people of all ages from everywhere. Like learning different dialects of the same language. Its all part of the learning curve of any trade.  Both those two terms describe to me perfectly that they are one and the same. After a couple of years of knowledge you can figure out what is being talked about. There are times that i get caught out with something i haven't encountered before.
    • Mike, you have summed it up following the KISS principle.   Tom
    • I think this is pretty typical when you have something that crosses many regional and international borders. @Neverenoughwatches yes Rich, that is the common way, learning from our teachers, however terms used in Yorkshire could easily be a lot different for tools, techniques or methods different from Scotland or Somerset. My (long winded) point is it all depends on where you first picked up the terms, if from books American watch terminology differs from English terminology and to a degree Swiss terminology. That also seems to extend to watchmaking schools. Confusing at first starting out but like anything else you get used to it. This will be why our long term members attach a glossary to new users introducing themselves as beginning their journey.    Tom
    • Personally I would just replace like for like.Or just polish the old crystal and refit.
    • I've also heard it called the "top side" and the dial side the "bottom side", which should make any non-repairer very confused. There are many examples and sometimes it comes down to personal preference. Personally, I like to say "dial train" whereas most other people would use the term "motion works".
