While restoring my Dad’s old Timex, I committed one of the cardinal sins of dial restoration and got too aggressive while attempting to remove oil residue from the dial. I got the oil off and everything else with it. 😔
I may use it as an opportunity to practice re-luming so not all is lost.
Would anyone know where I could find a replacement dial? 27970 10678. I’m not opposed to picking up an entire donor watch.
Thanks.
    • A helpful way in aid of assembly is to place all the wheels in their respective places, place to plate on the top and fit a couple of the nuts onto the pillars. This stops all the wheels wobbling about as they are lightly held by the plate, you can manoeuvre the pivots into their holes, using a tool , usually home made or can be bought on eBay. I made my own. As the pivots align and fall into place screw the nuts down a bit to keep up the tension on the plate untill all wheels are in place then tighten down sufficiently to keep the plate in place whilst checking the end shake on ALL wheels and their location when all is good only then tighten down the plate.
    • I'd say my Pultra 10 lathe. It is just so well made and everything fits so tightly together.
