Watch repair books
Hey again watch peeps. Finding a really good repair book can be a bit hit and miss, and when a recommendation comes along it can get quite expensive. So here a little discovery i made yesterday that should only cost you a few quid. I've had this book on my shelf for about 18 months, its not a big book around A4ish size with 200 pages and old, almost a 100yrs for the 1st edition. Now most of us have heard of Aegler, basically the manufacturer that put Rolex on the map, without Aegler they might not be what they are today. They had a very long partnership starting about 120 yrs ago, from what I've read more or less in each other's pockets since the 1920's, slowing blending together to finish as one company in 2004. The Aegler family also included the Borer family, through marriage ? The Borer family did buy out Aegler in the late 60's who eventually sold it to Rolex. One member of the Borer family was heavily involved with Rolex's design and technical department creating the Rolex Perpetual among others during his time, he was also on Rolex's board of directors this would be Emile Borer. I only realised yesterday after some reading that the writer of my book E.Borer being the same guy. For a few quid must be worth a read is it not ?
31 minutes ago, tomh207 said:
@Neverenoughwatches
i just ordered a copy Rich, got to be worth a punt for a fiver
Tom
The price can vary, i have seen it anywhere from £3 -£30. I guess its knowing what you are selling. I've only just started to read it. The section on escapement is really good even the  guy apparently had a brilliant mind its not super technical, inside is a pull out illustration showing 30 points to watch and why things happen if they are not set up correctly. The book was wrote shortly after he designed the Oyster Perpetual the worlds first fully reliable automatic watch.
I have the same book and it does indeed have a lot of useful stuff in it.
You had me a little confused when you described it as...
A4ish size
as my copy is almost exactly A5, but it is the same edition as yours, just love the adverts in the front..
If I remember rightly mine was just a couple of quid in and antiquarian book shop.
Haha yeah its sort of inbetween 4 and 5 ish. maybe more 5ish 😅. Mr. Borer keeps it mostly simple, the articles are 100 yrs old ish thats just how folk were then, some of it feels like he's educating a nine year old which suits me just fine 😄. Its interesting reading his views and theories on cleaning and lubrication, oil movement within components like the escapement and the very start of using chemicals for oil adherence and retention, its very clear that he loved an experiment or two since he was head of technical department of the most famous watch brand in the world. Even at almost 100 yrs old its made me look more closely at what i do, definitely should have read it a lot sooner.
    • Yes, barrel size.  A 11mm spring will push out into a 11mm barrel, no need to go 0.5mm smaller.
    • Hello All, I’m looking for advice about how to interpret the mainspring specs described in the GR documents and in the catalogues of online sellers such as cousins.  My problem relates to interpreting the value describing barrel size - I’m unsure what the last number REALLY refers to.   For example: 1.10x.0105x360x11  (This refers to GR2628-X) Does the “ 11 “ here refer to the barrel inside diameter of the calibre OR to the diameter of the wound mainspring before insertion? For example if my measured barrel inside diameter to 11mm, I would normally select a wound spring size a little smaller, say 10.5, wouldn’t I?  Or, does the barrel diameter described in the catalogue specifications take that into account and I would therefore order a catalogue size 11 for an 11mm barrel ID? Hope this makes sense. I can’t find clarification of this anywhere. Many thanks for any enlightenment. Cheers, John
    • Let's say, like in a watch, you have  a 70 tooth 4th wheel, which needs to make a turn in one minute, with an 18,000 beat escapement. 15 tooth escape wheel as usual, and a 7 tooth pinion on it.   70 x 15 x 2 /  = 300  That's 300 beats, and there are 5 beats per second, so divide and you get 60s, one minute- all is well. If we do 70 x 15 x 2 / 8 that equals 262.5. With an 18K balance, which will let the escape wheel move one turn in 6 seconds, the 4th wheel will have made like 1.14 turns. So the time display is running fast. But this comes to like 7.5 seconds over per minute, which is about double your gain (maybe I'm wrong- I'm mathing on my phone while writing on my phone 😄) but pretty sure the gain is more than you are observing.   A possible culprit is that crown/4th wheel isn't running true, and a tooth is slipping past a pinion leaf once per revolution. I've seen this. If the platform is original and it's a nice piece they are often pinned, so the depthing isn't an issue. If the platform isn't pinned, check the depthing. And at any rate check the crown wheel between centeres and make sure the teeth are running true.
    • Fast responses - thank you. Yes, I mentioned the 18000bph to illustrate that it's not a matter of touching coils, over banking, shortened hairspring etc. I even took off the platform and temporarily fitted a another NOS one also with 8 leaves and beating 18000 but the colossal gain is the same. I'm resigned to buying and fitting a new Gorge platform plus a 7 leaf pinion escape wheel but only if I think it will work; otherwise it's a waste of £200 and a couple of hours work. Hence the underlying question is: all other things being equal, what would the timekeeping effect be? Is it a simple 7/8ths as fast? Logic tells me it is but can it be that linear?
    • Sorry to jump in here guys, but I've read through this whole thread and it seems there are a lot of people who think joining Facebook means everyone will have access to their lives. You could make a Facebook account with a fake name. You could even use your real name if you wanted to and set it to completely private so people can't even find you in a search and you don't have to add anyone as a 'friend', so you won't see anyone's posts. Literally use it to join a group full of members of this site. Admins could even set the group to private and require a password of some sort to gain acceptance into the group, so you can be sure that it's only members of this site that get in. @tomh207 is right, the form with email addresses and names is a bad idea. That will be abused by scrapers. Facebook is only as personal as you let it be. You can be completely anonymous on there if you wish. Don't think of it as Facebook. Just think of it as a watch repair group as that's all you'd use the account for. It doesn't even have to be set up with your current email address. Make a random one on Gmail or any other free provider just for the Facebook account. Tagged you by accident and now it won't let me remove it 😂 @Neverenoughwatches
