Mimo Military-ish
..because everyone likes visuals here- just off the bench-  Mimo AS cal 1130. It was an country auction house purchase nobody paid any attention. It took all of a day to fix up start to finish. I only needed to remove the gummy oil and the wrist Rauchkäse. My obligatory new mainspring though there was alloy inside. Hand rubbed the old crystal...
I was quite impressed with the movement and the case here. Hefty and the way the screwback slides open...high quality.
...Is it from a military batch? No markings on the case back so dunno....and I don't know too much else other than prices for these things are all over the place. I paid less than 100 quid to get it to the states from UK. Imma wear it!
Edited by rehajm
22 minutes ago, RichardHarris123 said:
Do you know anything about the bar across the centre wheel?
...not other than holds the movement in place, wedged between the movement and the case back like the internal case back of a Smiths W10...and suspect it might have something to do with the 'antimagnetic' claim. I saw similar Mimo where the bar is affixed to the plate with case screws but they were missing here and the ends of the bar sit in the screw holes quite solid. I'll mess with finding new case screws if it becomes an issue...
Edited by rehajm
23 minutes ago, mikepilk said:
Lovely watch. Have a look here
 https://www.watchprosite.com/girard-perregaux/mimo-wwii-dienstuhr--a-closer-look/6.1004143.7068013/
Are there faint markings on the back? Could it be German military and the marks have been erased?
Looks like the radium is flaking
I looked hard with the microscope but couldn't see any sign of a a 'DxxxxH' stamping and given the original look of the case I don't think it was polished away...
...and yes - radium hands. Bad stuff and you can see the missing piece inside the crystal in the before photo. I take precautions but am not frightened of it, though I will pass on anything where its all turned to dust...
Edited by rehajm
  • 4 months later...
    • I think we've talked about this before, using a new mainspring to initially overcome the effects of more movement friction than there should be. The aim is to reduce all going friction not to push through the friction with more torque, that in the long run will create more wear.
    • Sensible precautions @rjenkinsgb. I remember as a lad, my mate's dad ran a garage. I can clearly remember watching him change break pads. He used an airline to blow the dust out, (when pads used asbestos), and  we used to practically bathe in "carbon tet". But then he did smoke about 40 cigs a day. Makes me shudder to think about it.
    • OK, a little bit more from today's lecture about the main springs. Generally, the spring in the barrel is limited and can't  unwind fully. With the blue line is shown the reserve/torque relation when spring unwinding is limited by the barrel. The green line represents the same when the spring is free to unwind fully And the red line shows the minimum torque that is needed for the movement to keep running. The yelow graph shows how the torque changes (from the blue) when the spring gets weaker (set) after 100 years of work. The purple line represents thinner and longer spring in the same barrel. As You can see, using thinner and longer spring will increase the power reserve. The 'set' spring will have the same reserve as a new one with the same sizes, only the amplitude will be just a little smaller.  Of course, this is true only when the movement othervice is in good health ( the red line is lo enough)
    • As long as you don't grind the stuff up and blow it around, you should be fine. Use a dust mask if in doubt.   The things I'm very careful of are: Radium lume - even the stuff that is visually completely dead and inert is still highly radioactive; it's the fluorescent part that decays, not the radium. A single speck inhaled or ingested can cause cancer, so store parts in zip bags and wear a dust mask & wipe your work area down after handling anything that uses it. A proper geiger counter is a good investment if you plan on working with vintage watches, so you can check for it & take appropriate precautions.   "One dip" & equivalents - the original type & the generic PERC dry cleaning fluid (Tetrachloroethylene / perchloroethylene) which is what the original one dip was mostly made of. That's toxic, a known carcinogen. Use in very good ventilation only & keep it sealed whenever possible.   The newer B-Dip is presumably a safer replacement.
    • Only 137% !  sounds like you're not putting enough effort in 😆.  I would think of it like cogs on pushbike.  Fastest speed to the spindle would be largest pulley wheel on the drive and smallest pulley wheel on the driven. If the motor was into a sliding bed you would have 3x4 ? Speeds.
