Fake Seiko?
pent
Watching this non-runner at a good price and got the seller to send me a picture without the back.  It looks like a 4R36A, but when I compare it to other pictures there's a few areas that look suspect to me, circled below.  I can't tell if this is just an older or less refined version of this movement, or if it is a knock-off.
Most pictures I see of this movement have a bridge over the wheel I circled, where this one has a screw and magic fingers seem more exposed.  The case and dial are very nice and I haven't seen the color combo before, which I like.  I wouldn't be opposed to putting an authentic movement in, but I want to make sure I take that into account for the price.   I included a picture of what most of these movements look like online with a good view of the bridge I think is supposed to be there (circled).
Any ideas from you Seiko experts out there?
image.png.6c313b2450ed3a328af82edbcbfd4da2.pngimage.png.b0a8619d9a133753b7b60019641c01c6.pngimage.png.cdc2e1d1d208837ecf4dff224452ae2a.pngimage.png.935c5b94c27f0a4019096dd3054807ca.png
Compared to images found with a Google search I would suggest the following
It is probably a genuine seiko movement but
1. In the top picture where the righthand red circle is the fixing screw is missing its head
2. It looks like the auto wind bridge is missing.
3. Going by the colours I would suggest it's what's known as a Mumbai Special.
That is if unfamiliar with the term, a watch made up in India from a random selection of parts and the dial is probably a reprint all put in a random case.
Depending on the price I might make a good practice watch or a donor for parts.
So a genuine parts watch with a reprinted dial is my guess
Thanks all.  Based on the potential cost of a new movement, and the fact it's a non-runner, I counteroffered lower and the seller took it.  We'll see what repairs it needs when I get it but I think it will be a nice watch once running.  My first mechanical Seiko!
Good luck.
All I will say is I have bought dozens of Seiko watches and not one of them where a what I call a honest watch, that is one where the case, case back, movement and dial where all from the same original watch with most having a wiff of Turmeric about them 😉
So good luck, hope it all turns out OK for you.
    • I will try this weekend.  I've tried several times with my cell phone and it's just too small and recessed to get a good picture.  I need to get my macro lens and tripod out and then figure out how to get enough light down the hole in the side of the man plate to  actually show the top of the broken screw. I appreciate the effort and will try and get that pic this weekend.
    • Hi,   My name is Simeon I am based in Sydney, Australia and have recently got into watch repair / watch making.  I am very much a learner having serviced multiple forgotten watches, some of which were actually successful!   I have a slowly growing collection of watches, mainly old Soviet, a few Japanese and (not pictured) some Raketas, a Poljot Alarm, an Omega Speedmaster Reduced and a vintage (1972) Tissot Seastar.  I like unloved vintage watches, with quirky faces and enjoy bringing them back to life through the simple(!) act of disassembly, clearing and reassembly. I am an Electrical Engineer who also undertook a trade apprenticeship so I am reasonably handy - It's fair to say, I know just enough to get myself in trouble.
    • ha ha looks like a WMD.....you know I want one now
    • I took a chance on a non running Cosmotron X8 ("perhaps just needs a new battery" said the advert). Sure enough, I open it up and it has the wrong battery installed (a Renata 344 rather than the correct Renata 386) and the screws holding the battery contact had been sheared off to half a head on both ends. Ho ho, I thought - there's the problem. I got the broken screws out easily enough and as soon as I placed the correct battery in place the balance started. This picked up speed when I reinstalled one side of the battery contact and looked like it was a runner. As I was trying to get the replacement screws in, I did one side but the second was a bit of struggle (hold down the battery contact against its spring while dropping the screw in with tweezers) the balance stopped again. This time it wouldn't start again. 98 percent sure that I didn't stick anything, anywhere important or break it in a mechanical way. The battery was in place for most of the struggling with the contact, so it might have had an intermittent connection which could have upset the electronics. I tried giving it a puff with the blower but the balance doesn't seem to rotate in the normal way, it seems to be held in a static position by magnet. It can be pulled out of this position but spins back and stops dead. This may well be correct for all I know. Anyway, does anyone know anything about these watches and can tell me how I would go about and fault find this? I will be servicing it at some point so should be able to rule out mechanical issues from an old watch but not sure where to start with the electrical part of it.
