My intended “Royal Oak” needs a bit of polishing
Are the numbers and indices raised? If so I would remove everything else and then print your own design or redo the original script. -
By LittleWatchShop · Posted
I am pondering polishing it blank and putting one of those decals like I have seen others do. Alternatively, find another dial that is the same diameter, remove and replace the feet. This looks interesting https://www.4customize.com/product/custom-watch-dial-decals/ -
I will probably be banished for the site but I would have to give it a good scrub. You will loose any remaining letting but I couldn't live with the dial like that. -
I didn’t articulate my initial post. When the crown fell off the second time it got completely lost. Attached photos are what it looked like originally. Will add another when I get home
Here is the case and dial. I replaced the crystal already. Not sure what I will do about the dial.
