Vintage Seiko Technical Guides
I would like to get the battery replaced in my wife’s Tag Heuer watch. Is this something I can do or should I send in to Tag Heuer? Is it missing a gold bezel? Seems online photos shoe one. See photos, Thanks!
I suppose it comes down to how often you'd use it if you can justify around £100 for the Bergeon compared to probably £30 max to make multiple ones.
The Barrel measures 21.75mm and the biggest Watch-Craft winder is 16.40mm The Winder is of a Swiss made watch so maybe Bergeon would be the only option, I know the did a Clock set that satrted at 21mm and that one just looked like a bigger version of their current winders.
By Embezelled · Posted
Thank you! Oh and too late to edit out some typos, but "will perhaps a Seiko Crown" was supposed to be "will perhaps get a Seiko Crown". And I realize now that A-O3 should be AO-3.
