Howdy Folks
Yes the problem of finding the software this is because he does not have a website he has the files in the file directory someplace so finding it becomes extremely challenging if not impossible. He should be here but is not? Try sending a private message to Frank @praezis It's his software he should bill a tell you worries currently hiding it.
By hofnerpres · Posted
Mmmm. Nice quality - Found a mark on the edge. Got it - Wittnueur - Revue. Marking. -
The spring should happily stay on the back of the day disc when removed. This has been floating around in a box for a while.
Yes I believe you will. Apparently there is another thin spring under the day ring, so be prepared for that to fall out of position. Thinking back, I don't know that I have ever done the M33 Day/Date automatic to see how that part is arranged. I have only worked on the M32 date version.
