DIY Cleaning Machine
Nice greg, i know very little about Breitling. Is it new ? -
So what is your absolute favourite watch or clock that you own ? It doesn't matter if you wear it or not ( not that you would wear a clock, but then i anticipate some unusual answers ) The "ONE" that you would not part with under any circumstances and why. -
I was gifted 2 L&R cleaners. I am currently using a Bulova watchmaster for cleaning. The one on the left is running fine and has a reverse switch. The one on the right does not have reverse and the power control only works on full speed. Heat seams to work on both. Yes I did break one jar transporting them. Does switching direction while running hurt the unit? Can the speed controller be repaired and how? Which one is the better machine? What are the 4 disks that came with everything? Thanks.
By BramleyGreg · Posted
I have this arriving on Wednesday... looking forward to picking it up.. I just love it on the blue. I cannot wait. 🤩 Greg. -
Thank you very much oldhippy.. it is most appreciated. 🙂
