I am looking at microscopes and have narrowed it down to Amscope SM-4TP or SM-4NTP.  I can barely wrap my head around focal length, FOV and depth of field and would appreciate any assistance.
From what I can discern the 4NTP has focusable eyepieces while the 4TP has an integrated dioptric adjuster.  The 4TP is a little cheaper.  What are the pros and cons of each?  Does it matter for practical watch repair workflow?
Would appreciate any input from owners of these 2 types of microscopes.
Here is a great review and hints on the features that are key for watchmaking. I have an Amscope, but wish i had watched this first. I bought directly from the Amscope site as they had a good discount on their site, so worth checking out too.
Hey waggy that is a good video but I think he gets the magnification wrong.  The objective lens is actually .7x to 4.5x so with 10x eyepieces it is effectively 7x to 45x.
He also doesn't mention focusable eyepieces vs a built in diopter.  Looking at this video and others like it I think where you adjust focus doesn't really matter, but please anyone correct me if I'm mistaken.
Focal length doesn't super matter for our purposes here. More than anything, it dictates the size of the scope. We're not super sensitive to that parameter. It's used in the SM head to vary the level of magnification, but since the size of the scope is what it is, and it's not extreme in any way, it's moot.
A wider FOV (field of vision) means you can see more at once. That's a good thing. I forget what they call it, but they have microscops with a "superwide field" or something, and that's not something to skip if the cost delta doesn't matter to you (or exists).
Depth of field is the range of whatever is being magnified that can be in focus at once. With really high levels of magnification, your depth of field becomes zero, and you can only see an area the size of your FOV in a plane. We're not talking about those levels here, but since you're working with three dimensional objects where the point of interest could be some Z distance away from the plane, it's good to have some depth of field. More is better for our purposes.
HOKAY. So. Last and most impactful question in your line of inquiry there: Where does the adjuster go? The difference is just what part the eyepiece adjuster is attached to. It ends up in pretty much the same place either way. It functions pretty much the same either way. The difference is that you pay for it once if it's integrated into the head, and you pay for it with every set of eyepieces if it's not. If you have no intention of ever swapping eyepieces, get whichever is cheaper. If you think you might like some 20X eyepieces for some reason (maybe watchmaking related, may not, I use mine to fix skipping records), the eyepieces are cheaper if you're not also paying for the adjusters. It sounds like in this case, you get a double whammy cost savings in that the integrated adjuster is cheaper, so that's a no-brainer.
I own an SM-4TP, and I shopped around to get the cheapest price on the auxiliary parts between Amscope direct, Amazon, eBay, etc. It's one of those white label Chinese manufacturer things where dozens of outfits are selling the same exact product with a different logo on the sticker. In the junk drawer microscope thread toward the end, I believe someone found a decent model for appreciably cheaper than the AmScope, so it might be worth looking into. I don't recall the exact permutation, but they may have a variety of options if they're still around.
    • Depends what sizes of watches you mostly service . If you were to say pocket watches then you might benefit by wholly replacing the 9010 for 9020. As a rough guide hp500 is twice the viscosity of 9020 which is twice the viscosity of 9010 at 20°c.  So hp500 would give you a more mid-range oil between thin 9010 and HP1300, but as it happens hp750 is more mid- range than hp500, but is that more or less useful when oiling a train of wheels. After the barrel arbor the jump down in pivot size is around half, then after the centre wheel maybe more than half until the escapement. And pivot size isn't especially a deciding factor, as the torque and speed of a pivot would be more relevant when thinking about which oil to choose. So 750 might only be useful on a centre wheel and nothing else, and 500 might be better than 1300 for oiling the centre wheel but still comprises the rest of the train, where 9020 would be ok for the train but too thin for the centre wheel, leaving only 1300 for the oiling of it. You see the problem we're having here. What can be ok for one thing is less ok for another in a different way, damping down power compared to oil spread.  Maybe mixing a drop from two opposite range viscosity synthetic oils will give you some approximate thickness oil in-between . You want a short answer now,  I tnink I'd go with the 9020. Now be prepared for a whole host of different answers.
    • So, working on watches and your karma at the same time: win-win situation!
    • @SteveF ,  Go on to Dr ranfft website,  Enter keywords Omega 26.5T3  ranfft .  There Dr ranfft  has listed all related calibers to this family, all which beat the same frequency,  any balance complete of this family fit your watch. This would only expenad your choice of balance complete.  Recolleting your hairspring is easy, but matching it with a balance of the family is challanging. Regs
    • Yes, it looks much better, but at this point the main thing is to make the spring in one plain. so picture from side will show this better. Now it is seen that #1 bending is needed, which is normal.
