I purchased a Rubis style F tweezer via eBay. The vendor represented it, correctly I believe, as new old stock. There doesn't appear to be any discussion about this brand on the forum, and there's little elsewhere when it comes to Rubis tweezers for watch repair, electronics and biology rather than for cosmetics. I'm curious about the reputation of Rubis as a maker of craftsman tweezers, and about the age of the one that I purchased.
Rubis is a Swiss company located in the Italian canton of Ticino. The founder made tweezers for watch repair. After his death, his daughter took over the company and started to focus on tweezers for the cosmetics market. Rubis has become a high-end player in that market, but it still makes craftsman tweezers. These are sold under the name Rubis Tech: https://www.rubistech.ch
As mentioned, mine is a style F. The tip is just over 2mm wide. It's probably stainless steel/onyx. As shown in the first photo below, it's engraved "Rustless Steel", nothing about magnetism. I should check how it reacts to a magnet.
I'm curious about how old the tweezer is. These days, the Rubis logo on this tweezer says Rubis Tech. As shown in the second photo, mine just says rubis, with the letter r overlapping the letter u. I learned from a search that at some point there was also a logo in which the letters r and u don't overlap.
I'd appreciate comments on the reputation of these tweezers and any information on how old mine might be. If no-one has any thoughts on age, I'll send Rubis a query via e-mail.
In any event, the price was reasonable (US$15) and I'm happy with the purchase.
Thanks
Edited by redge
I have a few Rubis tweezers in my collection.
They seem to be pretty good, very much on a par with the old Dumonts.
Here are a few other makes in my hoard which are pretty good and worth looking out for if you're buying used. All Swiss made. Siso (probably the least good of the bunch but still usable), Tanic, Ideal-Tek, Favorite, and a brand that I can't identify but they were obviously celebrating their diamond jubilee (unless that is the brand). I've got a lot of those.
Thanks Marc,
I've sent an e-mail to Rubis asking when it stopped using that logo. The photo below shows the current rubis Tech logo. The photo is from the Rubis website linked in post #1, in this case a tweezer made from titanium.
Edited by redge
Rubis responded to me quickly. It says that it changed its logo from the one in Marc's and my photos (post #1 and first photo in post #2) about 25 years ago, or in about 1998.
Edited by redge
    • Funny I should come across this particular thread because I have a hairspring that I’ve just knocked the collet off!! It was too loose on the balance wheel and I was trying to tighten it (of course I failed!).  So I’m looking for a new balance myself. The hairspring is in quite good shape but obviously doesn’t have a collet now, so I don’t know if you’ll be able to use it. I wouldn’t dream of trying to refit the collet myself because I know exactly what would happen!! If I wanted to refit the collet to the hairspring (assuming I can find the original as it’s on the floor somewhere!!) where would I find a taper pin small enough? As some of you may know, this whole thing is tiny!!
    • Thank you. No value to me, and I guess not much value to anyone else either - just practice fodder as far as I see them. Ingersoll might make a nice watch to wear if I manage to service it. Benrus, I suspect, is too far gone in terms of case and dial - no cheap ways of getting them to decent looking condition? I wonder how these old movements compare to modern Chinese ones? Probably not favourably, even if there's nothing broken in them? Progress moves on? I've got an old Slava that I'm quite attached to, so I won't be learning on that one.
    • Welcome to the forum. You're best starting with something that you know runs well and keeps good time. That way when you've stripped and service it, any problems are due to something you've done.
    • Welcome to the WRT-Forum! Sorry to say it, but you’re very likely to break or lose something when servicing a wristwatch for the first time — I’ve been there! So, if these watches have any value to you, don’t attempt to service them as a beginner.
    • In writing "shimming the staff" I was alluding to the idea trailed in the above referenced thread of inserting a hair along the staff which, as the discussion there covered,  could result in some eccentricity. By making a (more or less) complete cylinder I was hoping to avoid that problem. Don't tell anyone, but needing a very ductile metal to do this by manipulation at such a small scale, I used a piece of an empty Tomato pureé tube! It occurred to me that the material's ductility(?) would also put less stress on the RT in forming a sufficiently tight seal. Anyway, that's how I avoided the temptation to use glue. No doubt your punctuational response to this confession will be "!!!" !
