Seiko 6138
Couple of potential causes I'd think:
1.  The spring for the hour recording wheel stop lever has come dislodged, broken, or the eccentric pin has been turned (see Fig. 9 in diagram below), causing it to not apply the correct amount of tension to the stop lever
2. The stop lever has slid under the hour recording wheel (I've seen this on two 6138's I've worked on), although this would probably cause the wheel to not function at all rather than always run.
There's really only one way to find out though, and that's to take it apart and have a look.  Thankfully you can check the brake without having to remove the front chrono plate.  Pull the dial and hands off, remove calendar works, and there's a window that shows you the hour recording wheel and the stop lever meeting together.
Here's one I recently came across where the stop lever was on the underside of the wheel (probably not your issue, but you can check):
It should sit like this:
Edited by thor447
  • Thanks 3
  • 10 months later...
Hi all. This is a related topic and although the original poster has had their query answered, I could use some advice.  I too am putting together a 0040 Bullhead and it appears that the PO had turned the eccentric pin (hour recording stop lever spring axle) 90 degrees away from where it should be.  Attempting to turn it back I managed to shear half the axle head off after 45 degree rotation (so still out of alignment).  Any thoughts as to what is the best way forward now.
My thinking was to either:
1) Drift out the existing axle, turn it to correct position and refit.  I feel that there is still enough of the axle to hold the spring in the correct location.
2) See if the axle is available as a spare (though I can't see it in the parts listings) and replace OR
3) Get a scrap main plate, remove and clean up the axle from that one and replace into mine
1) is probably doable as a short term fix;  2) I doubt if this is a spare part; 3) anyone selling a main plate seem to be selling good ones at great expense.
Anyway, suggestions would be greatly appreciated and if anyone has a rubbish, not really salvageable main plate they were going to get rid of, I be more than happy to pay for postage and reuse one part of it rather than chuck the lot out.   Cheers, John
    • No idea Rich, but for your own sake please avoid inhaling the fumes.
    • I would try the vapour treatment very simple just a simmering pot of the stuff and jewels bluetacked ( not whitetacked this time, you still haven't said if I'm forgiven yet 🙂 ) to the underside of the lid. You're now gonna tell me that stearic acid can be highly explosive above 90° C 🤣
    • I guess it also depends on the precision and quality of the watch. He works on vintage watches mainly and surface treatments on 50 - 60 year old watches probably isn't going to make much difference. I read about nano coatings for car finishes. The article claims that nano coatings can reduced the coefficient of drag by 5%. Is that number significant? I don't know. Maybe if you were trying to break the land speed record. But applying that on a 50 year old clunker isn't going to make it go any faster, accelerate better or save on petrol. 🤣
    • 😅 yep certainly overdid it , i wasn't sure if i had enough heat so i went out and left it cooking. You can see the thick frosting, bit like my cherry buns.
    • 5 hours! You have slow cooked it! It must be really tender by now. @nickelsilver posted about his Greiner machine a while back. It had a heated chamber of stearic acid to epilame jewels and it only took 60 seconds. I've tried stearic acid dissolved in ethanol with a flake of shellac. I'm not really convinced by my test results. I conducted a side by side test by coating a mirror with a stripe of stearic acid and putting several drops of 9010 on the treated surface and untreated surface and observed it for several days. The 9010 spread out about the same for both the treated and untreated surfaces. I spoke with my mentor recently regarding epilame and lubricating pallet jewels. He has stopped doing both because he finds no significant improvements to the end result.
