Pierce Parashock Calibre 103 Sc Parts Needed
MStorms2672
Hello All!
I'm new to WRT and I just came into a collection of watches that included a Pierce Parashock cal. 103 SC.
After some research and help from another forum, I found out that I'm missing the center sweep second hand, second hand pinion, tensioning spring, and the wheel to acuate the pinion.
If anyone has an km knowledge of where to obtain these parts I would be forever grateful.
Thank you all,
Mike
post-1282-0-65920300-1436930906_thumb.jp
post-1282-0-96478900-1436930932_thumb.jp
Good morning and welcome to the forum Mike. I think your best bet would be a donor movement for parts or replacement, if you can find one. Is the extended pinion on the third wheel intact, or has it been broken off? I ask because it is not the first time someone has broken these and then removed the other components to allow the watch to still be used without the centre second hand.
I'm sure if someone here has what you require, I'm sure they will get in touch with you.
Best of luck! :)
I have a similar, non lume same movement, on the back burner awaiting suitable hands. The second hand was broken & I managed to break the hour hand when removing. This one required a new balance from Cousins.
I just got of ebay Pierce chrono model 134 (2 buttons) and it has same issue... no seconds hand, I did some research on Cousins and they have something similar to original hands, suisse made and Im thinking about this as a temp solution :).
    • A don't think so it leaked or damaged it because the watch itself works it just the buttons ain't working not connecting with the circuit board have taken more pictures of where the buttons makes contact with the circuit board.
    • I think what peter means oh is once he has fitted the hands and  checked for  alignment if them and that they dont foul, how does he then hold the movement to remove the stem in order to case up. The dial cannot be laid on a cushion or in a movement holder as the hands will get damaged. This can be quite tricky for a beginner, what i do is  to stand the movement on edge on a rubber pad so it doesn't slip. Hold the top edge with one finger then my dominant hand uses 3 fingers to press the stem release and flick out the stem. See below peter, leave off the second hand as this is the longest and gets caught the most, then fit it once the stem is out. Alternatively place the movement in one of the cup style holders, i imagine this is what they are designed for. They only touch the very edge of the dial.
    • Yes I understand that. What I’m asking is, after the hands have been fitted, it’s been checked that the hands do not touch etc. then I need to remove the stem to fit the movement in the case. I have the push type, I need to turn it upside down and push the setting lever post and pull the stem out. But of course the dial and hands are in place and I have a glossy dial with lume dots and I do not want to cause any damage while it’s upside down pushing on the post of the setting lever.
    • You have answered your own question. You just push the setting lever nipple in or if its the screw in type unscrew it a little. You should always remove any hands and the dial before putting it in your movement holder.
