Hello everyone,
I got a watch from my uncle 15 years ago and I have no idea what is I've been searching the Internet for very  long time just to know the exact model and if it is authentic . Please help me
Thank you
Hello Lowell, and welcome to the forum. Well done for finding the right section to post your query. There is also a section where we like to read an introduction from new members. It would be good of you to make the effort.
I suppose the easiest way to tell if it is genuine would be to ask your uncle, if he's still available. Maybe in round-about way you can find out where he bought it, where the box is, paperwork etc. JLC have produced so many models and variants over the years, you will be lucky to find an exact match on the internet without the exact model number.
Having said that, my guess would be fake. The finishing on the movement does not look to be near JLC standard. The rotor is especially plain.
12 hours ago, LowellAnora said:
Hello everyone,
Thank you
I would have thought some serial numbers would be evident on jlc. Have to agree with Klassiker, there doesn't seem to be anything that is stating quality.
My uncle is working in united-arab-emirates immigration from 80s to 2000 as a colonel, he said this was a gift from royals that gives them regularly expensive gifts, so when I check on jlc site and forums and even replicas I cannot find the exact details or even picture of this watch
    • Can you not remove the pin from the existing spring and just use that? I think if you did something like this you'd need to make sure the piece you cut off was long enough so the thickness didn't interfere with the stud staying in the hole.
    • Hmm ... I can't find anything with a pin like this. I guess with a lathe I could make the pin, then drill a hole in a regular mainspring and rivet the pin to it. Can't really see me doing that without a watchmaker's lathe, though. Am I going to have to shelve the watch because I can't replace the mainspring? There has to be another way. I wonder if I could cut off the end of the existing spring and use it as a catch for a modern manual-wind spring to hook on to?
    • Восток 2403/581096     So a while back I discovered the website of the Vostok factory. It didn't come up on google but was mentioned in some youtoob video. The information was all in Russian and the English translation wasn't fantastic. The "Put in Basket" button was translated to "Put in Garbage". The prices mentioned were also rather jarring. When looking at this piece the numbers were "Three THOUSAND .... two HUNDRED...." and I was thinking 'aww that's a big number' .... "err rubles". I googled the exchange rate and it turned out to only be 30 something squid, so I put in garbage. The postage said "eight HUNDRED ... and seventy!" and again I was thinking 'aww that's a big number' ... "err rubles". It turned out to only be around 8 quid for international delivery, so I threw in an Amphibia for about five THOUSAND - coz I'm such a big spender. I've replaced the straps on multiple occasions and have been abusing this ever since. Funnily enough fleabay would occasionally have similar models (not the sexy tilted dial) for about double the price. So it appears to be a decent business model. Unfortunately nowadays, and not entirely due to politics, it's gotten trickier to order these. The actual payment would need a slight workaround, and I wouldn't trust the Baltic postmen either (they appear to have a reputation of having sticky fingers). For anyone interested, and the prices would've changed over the years, and I'm not sure if I'm allowed to put url's in comments because I wasn't paying attention when reading the forum rules, is this: https://online.vostokinc.ru
    • Looking at the genuine Bergeon holder I expect the 0.8mm will be too big. Edit You should be able to check with the pins out of the holder if they pass through the surround to the jewel.
