Hello all,
Got this Tag Heuer Sel WG1210-KO from my friend, but the crown and tube were completely rusted.  Managed to pull out the crown and tube but they both need a replacement.  The tube was completely rusted, hence can't really take any measurement, may I know what is the right size of both crown and tube?  I found from Cousin UK, it seems the crown is 5.25mm diameter and 4mm depth, but not sure which tube size should I order.   Please help.
Thanks
Your watch stem is completely rusted away. You'll need a new stem. Is that an ETA 955 movement?
If the pendant tube is also rusted, you'll need to remove it from the case and measure the tube diameter and screw pitch. It can be difficult.
I did remove both Stem and tube, but as you said, the tube and crown thread was completely rusted hence couldn't measure its size.  Yes, the movement is ETA955.  I got a new stem already, but need to order a right size tube and crown.  Just don't know the size of the tube.
I'm checking on an SEL I have stripped here. The crown is 5.25 mm with what looks like either a 2.1 or 2.2 threaded inner tube, Cousins part number looks like C8612
For the tube, It's 2.6 OD and 7mm long. I can't be sure if it's ID is 2.1 or 2.2mm as that's the threaded part. I'm leaning towards 2.1mm so Cousins part number should be C8623. I would suggest you buy a 2.1 and 2.2 ID tube to be safe.
Edited by gbyleveldt
Thank you so much gbyleveldt for your advice and information.  I checked from Cousins, the ID2.2mm one says for Crown 5.5mm which I think may not be right for crown 5.25mm.  I think I will go for C8623 although its 6.9mm long which is for screw down crown as per Cousins.   Thanks you.
    • If a runner, I usually let the movement run in naphta for a minute, some movements need a bit of encouragement to run in liquids, so a quick dip of the movement in naphta then remove and encourage the oscilator with puffer, repeat several soaks.  Or if you don't want to soak or dip the movement in cleaning solution ,   keep putting naphta on jewel holes as the movement runs on bench. A pre-clean of some sort  helps.  Avoid lifting out the fork with tweezers or any tool.  Try blowing fork pivot out  with strong puff of air from jewels holes back side. Good luck .
    • 60! Wow, that's a lot. Can't say I understand the problem because disassembly is usually quite uneventful, except for springs launching into space. Most people break pivots during assembly. I use a homemade brass pry tool to loosen parts. It's just a short length of hard brass wire sharpened to a chisel point. Don't pry at just one point and crowbar it out. Pry at the notch and when a crack opens up, slip the pry tool in and loosen it at a few more points until the bridge is free.
    • Beginner here. Of about 60 watches I’ve serviced and repaired, I’ve broken a pallet pivot on three, always during disassembly, and usually when the old oil has transformed to glue. Each watch was Swiss, in case that makes a difference. Here’s what happened in each case: - unscrewed the pallet bridge or cock - gently inserted a screwdriver in the  slot under the pallet bridge or cock - gently but firmly rotated the screwdriver, avoiding a forwards force on the screwdriver. If alignment pins stick, the cam action is alternated back and forth between back corners of the plate. - heard a small but horrible click. Is there a special tool or technique for safely lifting the pallet bridge? Should everything be soaked in naphtha before beginning disassembly if there’s any sign of old oil gluing parts together? Thanks! Rob
    • You shared this test with me a few months back on a Hamilton project and so I had checked this watch to find the pins were still equally spaced. Their screw slots were undamaged and very tight hard to move so maybe no one has messed with them before. I can't work on it much today but I did measure the fork slot again and it seems like 0.44 is the right size. I measure the jewel that had been installed at just 0.42. would an undersized too narrow impulse jewel impact the impulse drastically? I ask because I have had it at a state where flipping the fork manually with a tool would unlock some of the time, but the balance was never capable of unlocking.
    • This was what I was afraid of. The movement is not one of the generic black square modules. Remove the movement from the clock and try prying it open very carefully, without breaking the plastic tabs. The plastic might be brittle from age. Clean the wheels and check the battery contacts for corrosion. Check the PCB for bad solder joints. Take plenty of photos along the way.
