Hi folks,
I'm hunting down a crystal for an old watch I'm learning from while bringing back to life. It's a manual wind Caravelle from the mid-70s. The acrylic crystal is cracked, so I removed it and see it is equipped with a tension ring (lesson number one for me, as I had not seen crystals with tension rings before). So, I did some measuring and research and see that there are perhaps four varieties of tension-ring-equipped domed acrylic crystals that might be what I need. For the life of me though, I can't figure out which one is for me (or perhaps any of them will work?).
Narrowing crystal manufacturer down to just Sternkreuz, I see the following four options (all in the diameter I need):
Standard.jpg.d16405a5dd917c2479f4652f2b5b60c3.jpgWide.jpg.bc4ad23535fbf17d23cd1d660fc44469.jpgRecessed.jpg.b1b3cfda5b01ba8ee3338622e33343d0.jpgHigh.jpg.6a834278e001c616c2ae67ce3fc0c8ce.jpg
Unfortunately, I can't seem to find specifications (beyond diameter) for any of them (including the Sternkreuz catalogue). Any advice on when you would use one versus another would be most appreciated. 🙂
For reference, measurements of the old crystal and case follow. I think I should order 30.1mm once I settle on the type (leaning toward the High Dome). Thanks for your help!
IMG_1022.jpeg.3acd571ece116990cd23f4449dec7153.jpegIMG_1023.jpeg.e553aa5872005cd475d96178a76be155.jpegIMG_1024.jpeg.11afb60d6e2d93a586660540340b24b3.jpeg
The Accutron Bullova Caravelle case parts catalog doesn't seem to have that number listed, it could be the watch was released after the last catalog was printed (1979).
  • 3 months later...
Here's an update in case anyone else is mystified by the array of crystal options out there.
I ended up ordering two crystals from Cousins. The Standard and the High Dome. Standard was closest to the OEM crystal in look/shape/height (although just a tiny bit lower) and High Dome was three or four tenths of a millimetre higher.
I installed the High Dome along with a new leather strap. I'll wear the watch for a few days to see how it performs before the movement goes into my servicing queue. Some related photos:
IMG_1259.thumb.jpeg.ccda7f27438849052322c3ed0e79303e.jpegIMG_1260.thumb.jpeg.e4b53f279c2daa94599a3e52892f6955.jpegIMG_1261.thumb.jpeg.10766c7a0f882382f874e306b7384f68.jpegIMG_1262.thumb.jpeg.a9819a27a07f30497345bce1edb25929.jpegIMG_1263.thumb.jpeg.a8c3220344cbb89dd71879f7c1930107.jpeg
And a before / after comparison of the watch:
IMG_0984.thumb.jpg.cc95d570c8ef8826e3955182325f02dc.jpgIMG_1264.thumb.jpeg.ae9e2b5374c2f94f60ac02183ddc0e1b.jpegIMG_1265.thumb.jpeg.e085c0469407261f216891a00f6f471d.jpegIMG_1269.thumb.jpeg.3781cc1f3833130b5de8a68c3a172031.jpeg
    • I'm sure it's the ancien. My measurements: A = 342. The slight bend in the pivot would make much less than a thousandth of a mm difference to this so I don't think 348 is plausible unless there has been significant wear on the pivots. B is hard to measure without first removing the balance wheel. I measured to the other side of the balance wheel as best I could (263) then subtracted the thickness of the wheel (69) to get 194. This could easily be three or four hundredths out, so 195 looks right. (196 could also be right.) J couldn't be measured. I did my best to measure where the balance wheel has been riveted on and got about 95, so 85 before riveting is plausible. (60 is not.) G again couldn't be measured without first removing the roller. I get 37 where the staff emerges from the roller so 41 at the other end of the taper seems plausible. (43 is also plausible to me.) K = 60. (Definitely larger than 55.)   I've never replaced a balance staff; it'll be a new adventure for me. I'll have to read up on how to maximise my chance of removing the old one without damaging the balance wheel without having access to a lathe. I also need to explore how to remove the roller without damaging it. I won't actually place an order until I've gone through the rest of the movement. With the number of issues I've already found, I'll be amazed if I don't have more surprises in store. There are some watch part suppliers in Australia but nothing like Cousins or Otto Frei or Jules Borel. AllTimeCo is fine for basic parts for modern watches: batteries, bands, some crowns, stems, seals, movements, some tools, etc., but not really anything for vintage watches. Australian Jewellers Supplies is similar. Cousins charges about £9 for shipping to Australia which is about AU$19 and not too bad (considering Australian parcel post is $11) but I still want to minimise the number of times I'm paying it. I need to explore other options closer to home. There may be something in Singapore or China that would have what I want and ship it faster/more economically.
    • Hi, I just finished the service of a Rolex 3135. Amplitude is great, 295 degrees horizontal after 2 hours and 280 after 12 hours. Vertical positions are 25 degrees down on those. I am however seeing a rate variation with temperature. I have 0 SPD on wrist, say 38 degrees and +7 SPD at 18 degrees room temperature. That equates to +0.35 SPD which is within spec I believe (+-0.5 SPD/ Deg C max). It just seems more than I would expect from such a high quality movement. To put that in context, I see similar rate variation with temperature for a Seiko 7S26. Just wondering what you guys see. Thanks, Steve.
    • For years I've done it the el-cheapo way (read: cleaning by hand). Bought a 2nd Elma S15(H) ultra-sonic, including proper cleaning-fluids (Elma WF Pro (cleaning) & Elma Suprol Pro (rinse)) and entered a complete different cleaning world. These cleaning fluids are none-water based and not that easy to obtain. Initially I bought these fluids in Germany "SKSONIC" (www.sksonic.de) but last year they stopped shipping international. Perhaps they resumed international shipping? You can always ask them. You could also ask @VWatchie, he lives "next-door". As for the fumes; I use the ultra-sonic in my garage, partly for the fumes, but more for our dog ...... he goes "bananas" when I switch on the ultra-sonic. Oh, next on your list (if you consider watch-repair as a long-time hobby), a Microscope (up to 50x is enough).  Pegwood leaves, observed under the microscope that is, whole tree-trunks behind 🫣 Ultra-sonic, in combination with proper cleaning fluids, takes care of the cleaning.
    • How do I remove the hairspring from an ETA? 2846. Balance  staff pivot is broken and I need to transfer the spring over to a new wheel. But the spring stud is not removable. It seems it almost looks like a snap ring at the top of the balance cock or am I missing something?
