Landeron 51/48 compatible modern cases
gkmaia
Hi, I got a bit stuck on my Landeron 51 restoration project. I can't find a modern case that is compatible with it. My main issue is not the diameter, but the angle of the pushers in relation to the stem.
I've tried some cases I got from Aliexpress:
  • ST1901/2/3 works perfectly for a Valjoux 7730 and Venus 188. But the angle of the pushers in relation the stem is incompatible.
  • VK63 movement case is too small for either a Landeron, Valjoux or Venus.
Anyone had any luck in finding a modern case that fits the Landerons?
