Hi there Anthony here...
Just restored a seiko 5 and need SEIKO 7009A INTERMEDIATE DATE WHEEL 817  024 WANTED.
lots of info on this site which looks good and I hope to make some great friends here.
let me know if you have this part as I bought a parts movement, so have lots of 7009A parts for sale or trade...
All the best and thanks in advance for any replies
Anthony7
posted this before but no reply.
Not knocking anyone but I'm not surprised as the structure of all these
what appear out of the box forum messaging post packages
are a bit all over the place...
So I get its easy to miss stuff as up to now everyone has been super friendly on here.
I did have one bloke reply saying he had one but his post disappeared weirdly.
as I bought a parts movement and that one was banjaxxed too and the part is discontinued,
I also have lots of 7009A parts for sale...
Are you allowed to advertise and sell stuff on here?
Although I'm not a merchant or anything just trying to recoup the outlay for buying the watch and the parts movement by selling what is left over as I'm sure someone needs some of it...
So let me know and all the best and thanks in advance for any replies and advice.
Anthony7
Moving to correct sub-forum.
Why is this happening?
Please don't be offended - from time to time, in an attempt to keep WRT organized, we need to move threads to another area more suited to the subject of that thread. Members can help the forum staff by checking for a suitable sub-forum before posting as this will help to reduce their admin workload.
    • isn't it nice to have a decent case open or when the case doesn't want to be opened? In the case of a Rolex watch that supposed to pass specific water resistant testing you probably do need to tighten the back down. But they shouldn't be tightened so much that they risk stripping the threads out. Then the other problem that comes up is the gaskets can start to disintegrate and then getting the back off can be quite a challenge unless you have a really good tool and perhaps some penetrating oil to loosen things up. Yes really nice case marking. When I was in school we were taught to mark the cases and  the American watch and clockmakers Institute even had a? So if you joined at one time they would give you an identification number. They were explaining or giving an example of if the watches ever found in you have a unique number they can perhaps figure out the history of the watch or identify the body it's attached to for instance not that that probably comes up that often. So you got a unique number and even made a special metal stamp that you can purchase. It wasn't a super big aggressive stamp but still it left a mark in the back of the case. Then I heard from people at work on Rolex watches they were using a felt pen indelible but later on they decided that was bad because apparently the ink could release  chemicals although it seems like once it's dry that shouldn't be an issue. Then of course today was nice is you can keep computer records sealed have to mark anything at all I personally find it's best to leave no reference behind that you were even there. Especially when you have a beautiful watch that has no markings at all and now it has your scribbling all over it not good typically if there is a typical and watch repair?  a lot of minor repairs you don't need to do a complete servicing. But beyond a certain point you're going to have to take apart a lot of stuff you're going to disrupt the lubrication even if it looks perfect right now and yes you might as well just go ahead the service the whole thing. also in a watch like this where a lot of things seem to be going on the complete service would be better then you'll know exactly where you stand versus dealing with unknown mysteries for prior repair.
