Movement identification
32 minutes ago, JohnR725 said:
you need to find yourself a copy of the bestfit book as it would help you to identify your movement.
http://www.ranfft.de/cgi-bin/bidfun-db.cgi?10&ranfft&0&2uswk&FHF_1146_10_5
Thanks for your help i did identify it in the bestfit books but when i went onto ranfft the back is different so was unsure if that made a difference to the stem.
do you mean like the back layout of the plates are a little bit different? As long as the wheels are in the right place in the watch more or less looks right it should probably be the same thing. Often times the movements get modified a little bit. Like you might have finger bridges over each the wheels or some other times it might be a much bigger bridge
oh the other thing to do is it suggested there were equal to other watches go a look up the other watches see what they look like
http://www.ranfft.de/cgi-bin/bidfun-db.cgi?10&ranfft&0&2uswk&Bulova_10AE
then here's a listing of stems compatible with yours. I don't suppose even have a partial love your original stem because if you did we could measure the dimensions and see if they compare to this stem
http://cgi.julesborel.com/cgi-bin/matcgi2?ref=V\ZDXK\[
39 minutes ago, Kalanag said:
The FHF Font 1146 obviously was produced with different bridge designs. I found this 😉
Thank you so much, that helps so much i'm still learning so your help has been great, again thank you.
Thank you you have been very helpful i really appreciate it.
