1.75mm THK Mechanical Watch
I suspect that with a production "run" of 150 pieces we are unlikely to ever encounter one in the wild. It is also water resistant to 10 meters. Who is going to wear a 1.7 million CHF (1.74 million USD as of this morning) watch in the water?
It sure is a technical marvel, but the primary purpose of a watch is to indicate the time clearly, and the watch face  is kind of small, compared to the entire dial.
To be fair, there are quite a number of high end watches where the watch face doesn’t occupy the whole dial, such as the Lange 1 of A Lange Sohne, but the watch face is still large enough to be legible.
For you and me probably but I'm not sure that's the primary purpose when you're paying close to $2 million for 1 of 150 pieces.
The Haldimann H9 Reduction has a completely black crystal through which you can't see the hands or the tourbillon. Not sure if it has a display back?
    • Ha ha, reminds me of this: "Don't go puttin' none of that stuff on my sled, Clark. You know that metal plate in my head? I had to have it replaced, cause every time Catherine revved up the microwave I'd pi$$ my pants and forget who I was for a half hour or so. So over at the VA they had to replace it with plastic."
    • Hello and welcome to the forum. Added a little help for you . TZIllustratedGlossary.pdf
    • Hi @VWatchie - I have model of this Mondaine quartz watch in my collection, just a smaller size. I bought it many years ago, new.  I wonder if  the crystal on your watch is original?  My original crystal was entirely flat.  I scratched it at one stage and replaced it.  There is a dealer located in the UK who sells replacement crystals for Mondaine on the big E - I bought mine from him.  If you PM me, I’m happy to forward the listing details - he may keep different sizes for the Mondaine range?.  The replacement he sent to me was a perfect replacement for the original.   On a side note, the Ronda movement in these is very easy and fun to work on.  They’re also very cheap to replace.  I learnt a lot about the big date complication when the smaller date wheel spring mechanism malfunctioned and the date changing stopped. I stripped down the movement and it went back together very smoothly and continues to work perfectly.  I like the streamlined aesthetic of the Mondiane line.  I also have one of their big date mechanical movements which runs on an SW200-1. The crystal on that is also perfectly flat, btw.   Cheers, John
    • I have a DIY version, it’s a voice coil from a 300mb disc drive and a vdu transformer , when you put the tweezers in they vibrate like a tuning fork  and come out clean. Could get an engine block in.
    • the arbor square out of place and mainspring thickness/height is what I would double check on this model....
