French 8 day clock.
Its made by Japy Frères with a cylinder platform its 8 day duration dates around the 1890. The problem with this type of movement is the great wheel the design has it so close to the edge of the plate and as the springs are so powerful that pivot hole wears and always moves to the edge, and in some I have seen it wears so close to the edge that it can't be repaired with out altering the plate. Nice barley twist decoration on the case which looks like oak.
    • I was wondering whether anyone could assist with some questions I have about my latest acquisition, which is a two train ‘Bravingtons Renown’ mantel clock - Pics attached I have done some reading about Bravingtons and believe they sourced movements from various suppliers, so I wondered whether anyone recognises this one. I have stripped and cleaned the movement and the clock is now running well, but there are a couple of dodgy brass springs that I would like to replace. I haven’t found anything suitable searching the internet so I wondered does anyone know of a supplier that might help. Last question is about the veneer on the case, it is generally in reasonable condition but there are a couple of patches on the top where the veneer has lifted. So far, I have tried to reactivate the existing adhesive by heating from below and above with a hair drier, then clamping for a day or two. It has improved slightly but the bulge is still visible. I’d be grateful for any advice if anyone has dealt with this sort of repair before.
    • Hi some pictures o& the movement and case would be appreciated so we can ascertain what the problem is you are having in fitting the movement.   Thank you.
    • Thank you very much,T. I'll try turning the arbour from the clock face end very carefully in case I haven't reassembled the suspension block correctly (I had to make up a suspension spring using remnants of a broken one as I haven't been able to find an exact replacement online).
    • Hi murks a picture of the front as well would help,   By the size of the plate it was stuck to I would suggest a coin cell,  2030,  2015 all depends on the height of the cell. And the space when the back is fitted.         3 volt.
    • We seem to have gone a bit quiet on this ?  Do we all agree to ask Mark for some input on this matter, or is no-one really bothered.
