Sooo, I have a question. Anyone know what is typically used on plating the brass plates of modern movements? I somehow remember it being mentioned that it's Rhodium, but that sounds expensive for mass produced movements like the 7Sxx and NHxx movements. Nickel plating maybe? I ask because I want to remove it and was hoping it's something I can do chemically instead of mechanically. And because the burning question is why, I'll say it's a surprise ðŸ˜›
Expand
Looks these like mostly nickel but it could be a proprietary mixture. Industrial electroplating can be very sophisticated, and non reproducible at home.
Expand
Sure you can try, if you have previous experience it would help a lot I think. I don't have that either but I know that's not something easy or cheap to do.
Expand
Hiya Gert. Sounds interesting. Plating is something i want to try also. Some of the watches i buy have heavily  worn plating, learning this goes alongside a full restoration.  I do know that chemical deplating is as simple as a reverse process of plating. What might be the hangup with rhodium ?
Expand
Hey Rich,
So if the brass plates are nickel plated, I believe it’s possible with a reverse electroplating process. I’ve nickel plated before as I’ve shown elsewhere so it makes sense that de-plating would be the reverse. I’ll give it a bash, although I’m concerned that there might be pitting of the underlaying brass, which I don’t want. I can also remove mechanically using glass bead blast, but hell I don’t feel like removing all the jewels or getting an uneven finish on the brass underneath.
From what I read, it’s not possible to de-plate Rhodium without ruining the brass layer underneath. I don’t know enough about this stuff but this theme seems to carry through in much what I’ve read so far.
Anyway, I won’t be plating the brass again but etching it. Don’t wanna give the surprise away so I’d rather not say more lol
This site says:
Brass should not be used as a base metal under rhodium in fine jewelry. Brass is cheap, and rhodium is precious. Because brass is used for inexpensive jewelry, a rhodium layer must be thin. But a thin layer wears fast. Brass is malleable, and rhodium plating would increase its durability but would not be a wise investment. Rhodium plated brass would need replacing every few months. You would soon end up investing more in maintenance than the jewelry is worth.
This site says:
The only way to remove the rhodium finish is to mechanically polish it off. This is not difficult on a piece where all areas are accessible to polishing tools. However there are some pieces that have areas where all of the rhodium cannot be removed, under stones for instance.
Thanks Gary, well only thing I can do is try it and see. I also felt it wouldn’t be Rhodium plated. I just wish I can remember where I read that. Anyway, I can’t remember what I had for breakfast but I can remember brain worms like that. Figures…
Hi Gert,
Hopefully you'll get it figured out. I was just curious so I did some google poking around. Both of the above links are more specific to jewelry but I would imagine that Rhodium is Rhodium and brass is brass.
Let us know what you end up with.
Gary
  On 6/21/2022 at 8:49 PM, gbyleveldt said:
Hey Rich,
Expand
If you've ever watch Jo. Nekkid watchmaker, he sometimes does plating. Once did  a deplate and was just a case of switching the electrodes over which pulled the plating off the watchcase onto a base material. This stuff is a bit experimental anyway. Calculating the subject area is always a guess ( you could try volume displacement) . Its something you will just need to keep an eye on while its doing its thing. Take beer and chocolate with you to stop yourself wandering off 😄
Edited by Neverenoughwatches
    • Use probably the same key as you wound it with - on the end of the cannon pinion is a square that the minute hand is mounted to. You just need to turn the square, which will overcome the cannon pinion's friction and set the hands. That said, this could be the reason your wheel and pinion were separated and thread damaged. If the cannon pinion had been rusted or seized on and it was turned, it could have damaged the connection between the pinion and wheel. If it felt like your cannon pinion could turn on the center wheel arbor before and there is some grease under it, this should not be a problem.
    • I've gone the threadlocker route having tried the material insert approach without success. The watch runs but I'm chary about winding it more than a turn or so in case the 'repair' gives way; still, there's an element of satisfaction in getting it going at all as it's a single bridge/plate design which I could only assemble dial side up & then flip over in order to be able to insert the 3 securing screws. The reassembly took a number of attempts over many hours but at least I got considerable manipulation practice & the experience will come in useful in future. I'm now faced with my ignorance about how to manually set the the time as this key-wound Waltham pocket watch doesn't have the usual pull-out stem facility. All I can think of doing is to adjust the regulator arm until it catches up with the current time & then revert to the central position.....
    • So the crown should be a 0.9mm thread as you've ordered. How do you know the thread size is wrong if you've not removed the broken stem yet?
    • You'll need to be extra careful with the Citizen as Information along with Parts and Donors are pretty much none existing. You'll probably end up having to use a stem extender, that's hoping there's enough stem left in the movement.
    • Thank you! That's immensely helpful. I appreciate the trouble you've taken. The initial hiccup aside, I do hope to treat this watch with great care and respect. I've certainly learned one thing not to do, and also just the general need to start out very slowly and very carefully.
