Advice on best Seiko for a challenge?
When I started I got a bunch of Seiko 5's of eBay, didn't pay more than £15 for any of them with most costing about £10, and that was often a complete watch.
Seiko have fitted many different movements to the 5 case so you get a few different versions to work on, I found the ones with 7009a or 6309 movements the easiest to learn on and the easiest to get parts for.
Talking of parts, I found it cheaper in the long run when a part is needed, because I found it broke or I broke it 😎 just to buy another movement and strip it for parts as I found the second hand parts sellers are basing their prices on new parts prices which is often higher than a whole second hand movement, that should also gives you spares for the next one, as long as you don't always break the same part.
Good luck in your journey.
Edited by Paul80
I would recommend a 6119 or 6309. Plenty around and cheap enough.
The reason I wouldn't recommend the 7009 and the 7s26 is that they are not as easy to get running right. The 6xxx series has a larger balance and I think that the hairspring is of better quality.  The 7s26 with its rectangular balance jewel spring is a challenge for a newby. I come across a lot of 6xxx and 7xxx watches and the 6xxx doesn't give much problems. Usually the only worn part is the automatic weight bearing and that happens on the 7xxx series as well.
Anilv
    • As Richard said, this is a really old school trick for joinery.  Cut i strip of paper, might need to be watch paper  around 1 " x 1/2" lay it over a staking block then press the stud screw into and through the edge of the paper upto the head of the screw. You probably wont even need to pull the paper away the head will pull itself through.
    • Thanks Jon, my mum is getting there day by day, so strong and determined, they dont make em like this anymore 🙂 Old folk are so amazing,  my mum used to love her golf, she didn't stop playing until she was 70 . Enjoy your trip and your golf.
    • Hello,  i am looking to source a winding stem (winding arbor) for a waltham 6/0 d movement. I have found some that claim to fit 6/0, 6/0s, 6/0b etc and somealso claim they will also fit the d as well. The d does have hacking which is driven by the stem seating completely. Given some of the costs of these, i was hoping someone would know of any interchangeability with a source, or know a source where a confirmed 6/0 d stem can be had. I am in the US so a US dealer is best.    thanks in advance.
    • So great to see and hear- your mum looks great! …my mil had a stroke last summer in the golf course parking lot. I’m flying out tomorrow to visit and play golf. she’s ornery because she can’t get off the tee but I hear she makes up for it on the greens since she’s been putting since a week after her stroke 🧐…
    • Very best wishes to you and your family, as a carer myself I know how difficult things can be.
