Morning all
Well I'm feeling quite chuffed with my self.
I wasn't getting on with my stainless steel tweezers so I bought some AA brass tweezers. So armed with these new tweezers I have stripped down the date side of my Salav 2414 movement and NOT had a single part enter the unknown area that's call the floor. I can also twist the smallest screw 360 degrees with out a single "ping" where did that go. This may sound very basic to veteran's but to me it's a mile stone won.
yes I know it's early but I was up at 5am and decided after putting my bins out I would dress my screw drivers under a loupe with a diamond oil stone 600, 1000 also while I was at it I started a spread sheet for screw drivers example Black 1.0mm length in jig 23.22mm Length in jig is so next time I get the same angel when it come's to redressing that screw driver.
I'm also getting into the habit of taking a photo before and after removal of a part.
I don't expect to reassemble the movement as it's a watch that doesn't work also it's been butcherer before found sealant as a o'ring and the dial is very bad shape looks like it's been hit with a hammer in some places.
BUT I haven't loss any parts I'm going to clean parts and then keep as spares.
Happy Noobie Monday
So far I'm not quibbling with my #2 stainless Horotec tweezers but I just ordered a #7 Dumont (bent - also in stainless) to see if I like them better for some things.
    • I have acquired a Citizen Leopard 36000 watch. My reason for purchasing it was my desire to own a timepiece with a 36,000 BPH movement, and the price was reasonable. Another motivating factor was gaining hands-on experience with the mechanism. The watch is in good condition, but I intend to fully disassemble it for maintenance. First and foremost, if anyone has prior experience with this particular model, I would greatly appreciate their insights. I do not have access to Citizen’s specialized lubricants and will need to use the ones available to me, such as 9010, 8000, and 8300 grease. Additionally, I do not possess the appropriate oil for the pallet jewels and will only be able to clean them.
    • Hello all, I am working on an older Valjoux Chrono. It doesn't have a stamp on the movement anywhere but I believe it is a Valjoux 72. I installed the train of wheels and they will not turn. The problem appears to be the 4th wheel and the escape wheel are not interfacing correctly. I had to replace both of these parts as the pivots were broken on each. I sourced genuine Valjoux/ETA replacements. I think the problem is with the escape wheel as all the wheels turn perfectly if I remove just the escape wheel.  My question to those with more Valjoux experience is am I mistaken? Is this some other model altogether and I have the wrong part or parts?
    • I would remove the wheels, check for damage and if not damaged, clean.
    • Thanks for the replies! Here's a photo of the front of the clock and a GIF animation of the movement (exposed by removing the black cap in the centre of the clock). You can see the behaviour of the gears. It's a fairly valuable clock from the 80s (Braun ABW 35). I'm not sure if replacing the movement would diminish the value, so I'd prefer to keep the original parts if it's easy to fix. But since the movement itself is pretty generic, I guess, maybe replacing it wouldn't make any difference with regard to the value of the clock? Or would it? I suppose the value is mostly in the design.
    • Well, my fundamental stance is that I want to go in and out without leaving any trace other than a shining, perfectly running movement. So, no scratchings on the inside of the case back lid, no marred screws, no debris, no fingerprints, and so on. That is, my goal is to make it impossible for the FBI to track me down. As a professional, I suppose you might want to keep track of returning watches, but as @JohnR725 mentioned, we can keep detailed computer records without marking the watch at all. That may not be true for every watch, but luxury and COSC-certified movements do have unique numbers. John also says it’s best to leave no sign you were ever there, and I couldn't agree more. Now, suppose the Sea-Dweller I'm working on is one day scrapped, and you want to sell the case-back separately (perhaps the case was destroyed in a plane crash). Then the scribbles on the inside no longer reflect the current movement inside the case. Also, the engraving will likely halve the market value of the case back. It had been "sleeping" for about a week and a half. Yes, the "debris/old lubricant" theory is my hypothesis as well! It will be interesting to see what I find once I have time to start disassembling the movement.
