Been working on another Vulcain Cricket.  This is a rebuild from a rusty start and a donor watch (also a rusty watch).
The hand was floppy on the cannon pinion.  Not sure how that happened--was not my fault--the watch came to me in pieces (the last guy gave up I guess).  In one of my watchmaking books, there was a mention of using a jeweling tool to close the hand tube, so that is what I did.
Of course...as delicate as I was, I overshot and ended up having to use a staking tool to open it back up slightly.  Got it now.
I have two of these Seitz tools.  One has a base hole of 3mm and the other 4mm.  I only had one solid stump and it was a 3mm one.  I prefer the 4mm tool, so I just let the stump "float" for this exercise.
How does the tool reduce the hole size?
is it a tapered sleeve that slides over the hand hole and squeezes it down?
The tools for this job are offered by Seitz - Bergeon. Any jewelling press taking 4mm stakes can be used.
Seitz - Bergeon 31000   Set of 4 Tools
Sizes: Ø1.25, 1.75, 2.25 & 2.75mm
For Seitz 31300 Jewelling Outfit (B59401)
Tools for reducing hour hand holes. These make it possible to reduce hand
holes very accurately, to within 0.005mm. It is essential to use the micrometer
screw for this work.
I had a concave pusher in my set that was big enough to do an hour hand.  It is almost the same profile as the hand closing pusher.  I'm sure the correct tool would have been better but it worked.
  • 1 year later...
Hello @LittleWatchShop,
Can this Seitz press (31300) also be used to reduce the diameter of the main plate hole for the barrel arbor. I.e. To reduce endshake for non-jeweled pivot/arbor holes?
If yes, probably with a hammer and not the micrometer. But can this tool be used like that?
Thanks so much in advance!
    • You could try a soft-solder repair on that
    • Hi Logan, welcome to the forum 👍
    • So I recently picked up a slim 6105 which had a badly damaged dial (posted in another thread). I couldn't really live with that given I had another dial handy, also in not great condition but with added bonus of having a better lume job and actually being fully attached to the dial plate!  So what to do with that damaged dial - I tend to think they should be in watches. Well...  A 6105 mid case and crystal assembly punt arrived from Italy yesterday, which I've frankened back into a working piece with the dial... Damaged dial now sits behind damaged crystal in an original case, currently powered by 6106 (with a 6106 caseback on to reflect this... I've cleaned up the original crystal up to a point, but kept it fairly beaten to distract me from the dial, my markers and it's not very satisfying lume job - it's not awful but it's glossy which I don't like. Also has a 6139 bezel on it for now because that's all I could find - I couldn't live with it naked and don't mind it tbh, though will keep an eye out as ever.  So yes, here you go - another 6105 (almost!) back to life. I'll also keep my eye out for the correct movement and perhaps a better dial in time. Caseback might prove tricky/expensive. I know Frankens aren't to everyone's taste but I do enjoy getting these back into working form. Better a working/worn watch than a sat in parts draws imo. And the good news here is that, thanks to the repro service crown, this is the only one I have I could actually feel safe to swim in!
    • I suppose the first question is have you got the correct replacement stem. If you've removed it in the setting position then you could try pressing the button while inserting the stem. Other than that it's a case of possible strip down to get to the setting lever.
