Overwound?
Plato
I just received a pocket watch which I was hoping had a Unitas 6498 movement, it did 🙂
The watch was described as being 'overwound', I think the main problem is all the 3 in 1 poured over the balance which has seeped through the entire movement!!
I'm going to stick the complete movement in the wash before disassembly and take it from there.
IMG_0001.thumb.JPG.1253dcd9b941d9f32173204f35a9d912.JPGIMG_0003.thumb.JPG.712a3e435b9a98b0772df134f40b3ac4.JPG
Yuck.  I think you're probably right about the extra oil, of the not-watch-friendly kind.  As many others on this forum will likely agree, the term "overwound" gets used way too much, particular by laymen in the sales advertisements for non-running watches.  Any watch that is wound all the way would happily unwind *unless* something prevented it.  The thing that prevents a watch unwinding is the thing we must fix.
And sometimes that condition is as simple as just a bunch of filth that needs cleaning out.  Here's hoping yours is that simple, and that once she is clean, the movement takes off running like new and will await her fresh oil and regulating!  I think I will check in on this thread later; I like old pocket watches.
I got the oil off the movement after two washes. The watch started running although very poorly.
Nothing wrong with the mainspring but the balance spring was out of flat and round, bug*er! All near the stud so not too bad.
I've corrected the hairspring but it's way off centre, I'll adjust the collet tommorow. Just noticed in the first picture more marks on the balance wheel other than my black mark. Also, in the last picture, one of the banking pins has been adjusted too. ... someone's been mucking about with this watch before me.
On the positive side of things, it's all good practice.
IMG_0004.thumb.JPG.f31570f32b8f0d5f1f557710ef6efbc1.JPGIMG_0010.thumb.JPG.d05aecf7d1e535631ef43ae5946f6156.JPGIMG_0015.thumb.JPG.55f30ba3ccce20dcd199c2930f2b7149.JPGIMG_0019.thumb.JPG.20677bdef8f8b33795e474b42a407ad8.JPG
5 hours ago, LittleWatchShop said:
Well, for 60 years I have scoffed at the "overwound" claim until recently I overwound my GMT chronograph with a Valjoux 726. I learned later that this is not uncommon. I think it is a broken crown or ratchet wheel. Next year I will get the guts to fix it.
Well, there I can agree: "overwound" -  in the context of having cranked  a watch so far that something broke could indeed be termed "overwound".  I suppose I'm only scoffing when I hear it used by sellers or lay-people to refer to a watch that does not run no matter how far they wound it, yet is mechanically complete, so they have no clue what's the matter with it.  It's too often used as a catch-all phrase.
Sorry to hear about the Valjoux 726.  I guess they can be a tad fragile then?  I hope it will be an easy fix for you.
I am quite anxious about it frankly. It will be my moat complex repair to date.
It is my understanding that this is a common problem with this movement. I have the suspected replacement wheel and the teeth are pretty dainty. More so than anything I have seen before.
I agree with on the general overwound comment
I am still skeptical that "overwound" is a valid diagnosis. Blue steel mainsprings don't break because you did something wrong they break because the metallurgy is vulnerable that way after many cycles of use and that is why we have modern alloy mainsprings. If you effed up your keyless works that is probably because of a design defect with your keyless works or because, like my ST36 watch, the stem is a hair too short.
But it looks like it is running fine now, to me.
    • I’ll take a counterpoint on the youngsters- all the under 30s in my extended family are into fashion and trends and have varying jobs/careers where the only common denominator is they provide the disposable income to buy watches, sometimes expensive ones. Most are very excited about my ‘new hobby’ and I’m spoiling them on their birthdays this year with a rescue- the weems already went out but here’s the rest… …I’ll share in the guilt of inflating prices for the stuff what once could be had for a few quid. Except for the 404 a good thing I say…
    • @LittleWatchShop thank you for the advice.  @Neverenoughwatches here are all the angles I could think of. If some are missing I can take more. Sorry for the quality they are taken through a phone.  @Neverenoughwatches here are all the angles I could think of. If some are missing I can take more. Sorry for the quality they are taken through a phone.   Note that after I was so happy to see it oscillate I screwed the cock and it stopped. I have been trying to make it restart since
    • To get the fork to engage the roller jewel, preset the fork toward the center of the movement.  Then as you are bringing the balance to the movement rotate it 90 degrees CW w/r to its final position.  Then as you drop the balance in, rotate the cock CCW toward the final position. Let the cock rest in the final position as you gently adjust the balance into position.  With power on the train, the balance will engage with the fork and start to oscillate.  That tells you that you have the bottom pivot in place.  Then while holding the cock with a piece of pegwood, adjust the balance until the upper pivot falls in place. This is my method.  I am sure I did not come up with it...saw some video some years back.  Perhaps one of Mark's
    • Best way to determine if there is an issue with the first balance assembly to take a few pictures of it from a few different angles and post them here. As a beginner it can be difficult to figure out if something is broken or not, you need to know what something in good working order should look like first .
    • Thanks to this video I undid the tangle.  The spring is still out of round and the watch is still not starting when I put the balance in place.  Since now I have a second movement, I’ll try swapping the balances to confirm that is the issue The result is not very conclusive. Swapping the balance didn’t make the first movement work. BUT, when putting the good balance back in the good movement I had a hard enough time doing it (it did work in the end but I think my problem is managing to sit the balance pivot in its bottom jewel or to fit the impulse jewel into the fork) that I keep wondering if the failure in the case of the old movement is because I broke it or because I am not good enough at reinstalling balances.  I confirm that the main issue is between the seat and the tweezers.  after more effort the first movement with its own bal and ou of shape spring started.  No doubt the time keeping will not be good but IT’S ALIVE!
