Hi all,
This tailstock came with a Boley Leinen 8mm lathe and I have no clue what it is used for. I'm hoping someone can tell me.
Thanks,
henryr
There were a number of Boley Leinen lathes made for specific purposes (contact lens making being one) but I can't figure out what yours was used for.  I have a feeling if you take it all apart you'll see it takes 8mm collets and is quite useful but hard to tell from the pics.
Thanks for the reply. I've disassembled it and the small shaft with the  very small center hole, in the first pic, is removable and it slides into a larger movable shaft. With the small shaft removed an 8mm thread is exposed in the larger shaft but it won't take a collet because the unthreaed opening is smaller than a collets outer diameter.
