Stubborn snap-in case back
Hi, Does anyone have any advice for a stubborn case back that just will not snap back into place? I'm using a case back press but all that is happening is the bottom die is flexing. Its the right case back, the gasket is good and correct.( the one that came off), It is aligned properly but it just will not seat.?
I'm about to resort to my shop 20 ton press.☠️
10 hours ago, ShawntheBrewer said:
flexing.
Always nice to give us pictures.
shop 20 ton press.
Did you notice if you are assortment of dyes for your case press is proper they come in a variety of shapes and sizes? Some case backs need to be pressed on the edges otherwise if you try to push in the middle they will never go on. Even with a 20 ton press if you're pressing in the middle the outside edges flex out and they will never grab. But the watch might look quite interesting if you flatten it with a 20 ton press. Other watches do require pressing in the middle so you have to press in the right place not necessarily with lots of force to get the backs to go on.
Thank you for this. It never occurred to me to press on the outside edges. ?
    • I haven't yet but I will take it out tonight! Thank you. Will post pics of dial side tonight too.
    • Did you have a look under the ballance? Often the movement maker/number is hidden there.
    • I wonder if 9415 is based on a base oil of 941? it's interesting what questions bring and the tech sheet answers it's the viscosity of the base oil. Then the impact? There is something we're missing here for that which would have a big influence on all of the house image above is 9514 image below is 941.then always interesting when specifications do not exactly agree? They ledge above for 941 indicates 110 viscosity but the image off the spec sheet is slightly less but I guess close enough   my understanding of the concern of too much 9415 is as we know the loss of amplitude. But why do we have a loss of amplitude? So impact it's basically oil should be very slippery. But what about non-impact? Like the edges of the escape wheel? Another thing that comes to play here is the shape of the escape wheel itself. Notice on the last a more vintage escape wheel with just a flat surface whereas the modern escape wheels usually made out of steel versus grass much much thinner their contact areas greatly been reduced and sometimes I think there even slightly curved. So is it conceivable at everything that isn't a flat surface on impact is going to be sticky? So this is where the shape of the escape wheel will have a big impact literally on how slippery things are. Oh and for all of you obsessed with worrying about too much 9415 I never worry about it because typically I'm doing pocket watches and it doesn't seem to be an issue at all. on the other hand I'm much more concerned about a watch that keeps time for 24 hours as opposed to the concern of the group of keeping amplitude for 24 hours. Then yes some pocket watches have steel escape wheels and do look like the escape wheel on the right.
    • your balance wheel looks interesting in the watch and because it's at an angle it's changing things a little bit. in other words they hairspring is not centered between the regulator pin in the boot and I also noticed your terminal curve is lacking apparently by design? Because if you look in the second image you'll notice yes there's a terminal curve but not as aggressive a one as you normally see on watches at least most watches.   then in all of your images it looks like the boot isn't quite back where it's supposed to be? out of curiosity how did you remove your balance complete and clear the regulator pin? then just in case you weren't aware it rotates out of the way so you can remove the balance complete without bending the pin. Then it's rotated back exactly 90° and yours looks like it's off by just a little bit in the original image and I'm assuming that you just been the pin out of the way? it's always interesting in horology is the variations in the things. Like the image I have above does have a terminal curve but not the most aggressive and yours is even less but that is the way the watch was made. Then the spacing between the regulator pin in the boot should be relatively small basically if you had two pieces of the thickness of your hairspring that's how much space should be there like in this image. But oftentimes watch manufacturers do not necessarily follow the rules
    • Yep i can see where you're going with that one Rich.  Sooo now that I've frightened the OP into submission 😁. Chief i do apologise for some reason unbeknown to myself I'm in a happy silly mood. So seriously to identify the movement lets have a look at the dial side, learning this part is straightforward, just need a little logic and something called the # BESTFIT BOOKS # . Or the other non American equivalents.
