Tissot cal 2481 date wheel to hands syncronisation problem
Hi I'm seeking from any anyone who has had this puzzling problem I have on a Tissot cal 2481 that I recently serviced. When setting up the hour and date hand to coincide with date click over at 12pm I observed the following. When I revolve the hands through 24hrs the date no longer clicks over at the same hand position. It is now at 12.10 and so on the more days I revolve the hands . First time I've experience this on a watch, any ideas?
Hi I think the convention was to set the hands the start changing the day/date at 11.50 allowing the wheels time to overcome the detent spring, the completion being in or around 12.00. Thats how i set them up. I may be wrong but I am sure other  members will have their own ideas.
Looks like a good look at the calendar works, dial removed but hands fitted is in order to understand what causes the timing shift. Was the watch keeping a good time, is a dial washer fitted.
Finally worked out the cause. 4 complete revolutions the date clicked over at exactly the same. The next 1 was out, the following 3 was perfect, then out again and then twice perfect. Took it apart again and their it was, uneven wear on some of the date wheel teeth. This was causing the date changing arm of the star wheel to not turn the date wheel enough so that the sprung loaded locking arm couldn't flick the date wheel that final bit. There is always a first time to learn something new.
    • Off topic, but that just brought back an old memory! My mother once told me about a minor incident as a child (born 1917, so 1920s, at a guess). She used to use "Fish glue" for a hobby - an apparently smelly glue that had to be heated to be usable - and to heat it gently, she had to stand the tin in the kettle.   One day someone filled the kettle without seeing the glue tin.. The tea tasted of fish for some time afterwards!
    • As Richard said, this is a really old school trick for joinery.  Cut i strip of paper, might need to be watch paper  around 1 " x 1/2" lay it over a staking block then press the stud screw into and through the edge of the paper upto the head of the screw. You probably wont even need to pull the paper away the head will pull itself through.
    • Thanks Jon, my mum is getting there day by day, so strong and determined, they dont make em like this anymore 🙂 Old folk are so amazing,  my mum used to love her golf, she didn't stop playing until she was 70 . Enjoy your trip and your golf.
    • Hello,  i am looking to source a winding stem (winding arbor) for a waltham 6/0 d movement. I have found some that claim to fit 6/0, 6/0s, 6/0b etc and somealso claim they will also fit the d as well. The d does have hacking which is driven by the stem seating completely. Given some of the costs of these, i was hoping someone would know of any interchangeability with a source, or know a source where a confirmed 6/0 d stem can be had. I am in the US so a US dealer is best.    thanks in advance.
    • So great to see and hear- your mum looks great! …my mil had a stroke last summer in the golf course parking lot. I’m flying out tomorrow to visit and play golf. she’s ornery because she can’t get off the tee but I hear she makes up for it on the greens since she’s been putting since a week after her stroke 🧐…
