Hi all... I’m cleaning up this Pogues here and have notice that the internal bezel doesn’t quiet turn fully over.. after further inspections, I know that half of the teeth that turn this haven been ground down. Therefore the gear does not turn this..
I want to keep this original, does anyone have any ideas on how I can repair this. Perhaps with some dried glue and the gear with just dent it?
Hello, to answer your question this is what I would do as a Seiko collector. Don't put any sort of glue on your chapter ring as over time the fine particles will wear of and foul your movement. If you need the Watch to be fully functional and original I would ask around every watch repairer and see if you can buy an original ring.Repairers such as Spencer Klein and anyone in your area, it may take a while but eventually you will track one down. Otherwise you can put an aftermarket one in, that's if you need it to be functional. These watch are very collectable as you are aware no doubt. If the Watch is totally 100 percent original I would not be to worried if it does not work, as originality is where value lies. Especially if it's a genuine Pogue 6319 6002
Hope this helps
