Hello everyone
I am trying to remove the movement to clean the case. I don't know how to remove the crown and stem.
I appreciate any help and advice as to how to remove the rust.
Thank you
  • Confused 1
I’ll take a guess.
The hole above the “H”- press down gently while pulling the crown.
I could be wrong too so get the loupe on and some light in there.
Thank you Tudor, it worked. I had tried that hole already but got scared as the crown wouldn't come out. This time I pressed harder and the crown just fell out. Thanks again for your help.
Hi
Do you know what kind of screwdriver I need for that tiny screw?
I have a set of micro screwdrivers, smallest 1 mm wide,  but the tip is to thick for this screw.
I managed to remove the rust from the case and other parts.
Thank you
20 hours ago, thepasserby said:
Hi
Thank you
You should buy a watchmakers screwdriver set. They usually have 0.6mm and over.
This is a good set (value for money) if you're going to keep practicing watchmaking but you can find cheaper ones (non-swiss or replicas in Ali and Cousins as well) -
https://www.cousinsuk.com/product/cousins-swiss-style-stainless-steel-9-pieces-rs
Edited by Rafael
I think A-F is the best "bang for the buck" in tools. A lot of my first (and some enduring) tools are A-F brand.
That said, I got a set of Burgeon screwdrivers, in a rotating stand (set of nine) on special for $90 a few years ago from Ofrei. I see similar ones on eBay, for $135 these days. You might find a deal around if you keep your eyes open.
Nine nice drivers with one spare blade for each for ~$100 in a nice rotating stand is a pretty good deal.
I gave up on regrinding the blades and buy ten packs of Burgeon antimagnetic replacement blades as needed from Startime. Much better than the original included blades- finish is mirror and they work great. Old blades get reground into other tools as needed, or scrapped.
My input on the screwdriver issue...
Edited by Tudor
