Lighter Fluid
Hi Rogart, recently I started using Fast Panel Wipe as used in paint spray shops. Here is the brand that I am using, I purchase it from a local spray shop supply shop at a cost £15.00 for 5L. There are two types, a fast and a slow, it is the fast that you are looking for.
http://www.ebay.co.uk/itm/U-pol-System-20-Fast-Panel-Wipe-Degreaser-5L-UPOL-Panelwipe-/381087467644?pt=LH_DefaultDomain_3&hash=item58ba95487c
I ran a test with Ronson lighter fuel, Fast Panel Wipe and Bartoline Turpentine Substitute (white spirit). I placed one drop of each on a clean sheet of glass to see what residue is left after evaporation. I was astounded at the result, white spirit although slow to evaporate, left no visible residue at all. Lighter fuel and fast panel wipe took the same time to evaporate and left exactly the same faintest ring of residue.
My understanding is that "Zippo lighter fluid", "Ronsonol" etc. are pretty much the same as "naphtha", which in turn is a range of light petroleum distillates. No two brands are exactly the same, so before using it for cleaning you should do the glass test (put small amount on glass and let it evaporate) and check for residue.
(The Swedish equivalents are "Kemiskt ren bensin", "Heptan", "Rengöringsbensin" & "Industribensin". "Lacknafta" is pretty close, but is more fatty and evaporates slower.)
Edited by Rob
    • So I found what I believe is the setting lever screw! Am I right in thinking the screw next to the click is the correct one for the setting lever? However if it is, it doesn't fit in the hole which I believe is for it! I can get the lever to sit nicely on the stem and line up with a hole, but the screw only goes as far as the shoulder and stops. It's as though the hole is too small! The dial side has been disassembled by the way, the other wheels are in my tray
    • When faced with say a pocket watch bridge which is cracked, silver soldering to repair is often the only option (hopefully someone wasn't there before hand with soft solder). I can generally do this succesfully and tidily with a small torch and miniscule pieces of silver solder, but on parts which were mercury amalgam gilded the heat can have have a deleterious effect on the finish.   I keep wondering if there's a good way to refinish these - and despite having the needful items would rather avoid using the mercury process.   In the past for electronic work I've gold plated PCBs but this involved gold potassium cyanide solution, which also doesn't realy belong at home. I've read that there are now safer alternatives but couldn't find more detail (and importantly how similar are the results to amalgam gilding, since I wouldn't want to refinish the whole watch). Pointers would be very welcome (and yes, I know solutions containing gold won't be cheap!) Alan
    • The first one is an Unruh max stake for pushing out staffs
    • Ok so with the great answers for my previous question may I ask what these two attachments are used for. The one with the red knob is I assume used for hand setting the seconds hand? Jon
    • According to Cousins site I need to look at document G22 as I think I need an ATGB at 304 but I cant find this size in G22 doc. The last thing I want to do is order the wrong one😳  Unless I cant see the wood for the trees 😆 I could be looking at the wrong style, I assume its classed as Round plastic Armed  https://www.cousinsuk.com/product/wide-ring-gold-atgb
