Cant find the trademark but I am certain the movement is a French Japy Freres  8 day cylinder platform movement made around 1900 identifiable from platform shape and separate bridge plate for the barrel , made with both round and square plates and used in thousands of timepiece wall and mantle clocks.
Maybe a retailer or importers mark
I think your clock would be late 20's early 30's in production Japy during that period were concentrating on making affordable clocks for the masses, there are thousand of the type of movement you have in your clock around in early 20th century French clocks, they were eventually killed off by the war and could not compete with other french manufacturers Jaz, Blangy and Duverdrey and Bloque who produced  Bayard clocks.
