G-Shock O-ring replacement
I've been trying to replace the battery in my G-Shock 5600. I've been able to remove the backing, replace the battery. However, I'm having issues with trying to refit the O-ring which looks to somehow have expanded to be far too large for the groove into which it should fit.
What size replacement O-ring would I need to replace the existing ring? Should I use a sealant with the ring?
