Has anyone ever made a spring bar or know anything about how they are made?
By LittleWatchShop · Posted
Maybe show us 1) the watch, 2) timegrapher readings in DU, DD, PU, and PD. -
The timegrapher displays significant beat error variations in the dial-up position. When the watch is lying flat (face up), the beat error is much higher than in other positions. Beat error readings are inconsistent, with especially large gaps in the face-up position. Please help !
Looks like an open-access journal that runs as a glorified pre-print server with no true peer review, so it’s not easy to judge the veracity of the conclusions.
Update: I got my "four inch" auction faceplate and I measure it at 98mm, fits my WW lathe nicely.
I’m sure these will be good enough for me to take my movement apart a few times. Regards to oil, I’ve heard the specific movement I’ve bought often comes dry which obviously can be an issue although they still run.. I may also just use a basic oil as I highly doubt I will be using the movement for anything other than practice. Thats assuming I don’t break half of it on my first try 😂
