There are plenty of old watches about ranging from say 10 to 30 years old that don't keep good time any more.One for instance that I have at the longer end looses 30sec a day. Another more recent probably 15+years old 15 secs a day.
I wonder how much of this is likely to be down to lack of servicing and or general wear and if that which parts are most likely to need replacing.
:mellow: Makes me wonder why people buy them other than this may be better than some new automatics.
John
A well maintained watch can last many, many years without loosing their ability to keep time. Servicing on a regular basis is the key.  It was not unusual in past decades to have a watch serviced every year. More modern timepieces that are lubricated with modern oils can go much longer, five years is a decent rule of thumb.
The problem with *not* servicing a watch is that dirt accumulates in the oil, the oil can also degrade, and if this is not addressed then there will be excessive wear on the parts. Dirty oil can become an abrasive instead of a lubricant :-). Once parts are worn it becomes more difficult if not impossible to bring a watch back to spec, parts might have to be replaced assuming that they can be found.
As the number of complications in a watch goes up (i.e. chronograph) , it is even more important that they be attended too, as the basic movement often has to work harder to drive the extra components.
I, along with other people here, have watches that are 75, 100, or even more years old, that are perfectly acceptable time keepers.  I don't have any old chronographs myself, but I am sure that other people here do.
Maybe someone here with an old well running chronograph will chime in!
David
I got off to a bad start on this thread. Title should be chronometers - automatics. Maybe a mod can edit it for me. My brain was elsewhere when I posted. It came back as soon as I looked at the thread again. :wub:
John
Same answer applies, minus the bit about complications :-)
A skilled watchmaker can usually bring a watch back to COSC specs, depending, of course, on the condition of the watch.  Even a basket case can sometimes be brought back given sufficient application of currency.
    • Hello and welcome from Leeds, England. Yes, you can use a modern mainspring. Breaking grease, protects the barrel from excessive wear.
    • It depends what type and era of watches you think you'll be looking at. The ETA mentioned by @HectorLooi is a good option but you could look at some Seiko/Hattori as a lot of off brand watches use these.
    • Probably any of the ETA quartz movements. I like the 955.112 as AliExpress has the PCB. But probably get a lot of quartz watches from eBay and see what you get. I've gotten a batch with a Bulova quartz and a 214 and a couple of Fossils. Totally worth it.
    • I had to go back and verify what were talking about because I wasn't sure with the terminology what exactly you are discussing. Then yes depending upon where you are on the planet and when you are there is all sorts of differences. When I was in school the instructor George showed me how to make one.  Such a simple device to make and so incredibly useful for 18 size full plate watches I wouldn't think of putting one together without it.
    • Recently, I serviced a Gruen 490SS automatic but ran into a mainspring issue. Apparently, this movement uses an older style automatic mainspring. Rather than a bridle, a short piece of mainspring is wound into the barrel with a metal tab at the end facing toward the arbor and a regular manual mainspring is inserted inside this. I suppose it still needs braking grease, but I am not sure. this is the first time I have run into this type of automatic spring setup. Well, I broke this small piece. Any ideas of whether I can replace this whole system with a more modern bridle mainspring or possibly fabricate this smaller piece of mainspring out of the end of another mainspring? Below is a photo of the original spring, a new spring I bought, and the small piece and its broken end tab, all seem to be old. Loved working on this movement and very bummed I was so clumsy and didn't think this through before taking it apart. I have about 20 working watches now (and many non-working projects mainly due to my poor judgement). I am learning (and relearning, unfortunately) not to go into an unknown situation without doing some research and careful thinking. I seem to need to relearn this lesson too often. Anyway, I would appreciate any advice. First time using this forum and a graduate of Mark's first 3 courses and loving every minute of this most rewarding hobby.
