I have two of the same Swiss army watch. I need to replace the stem and crown's on each. I cannot find any info online, regarding where the stem release would be.
Can someone please help.
Thanks
On 8/27/2019 at 9:55 PM, m1ks said:
At a guess, I'd say either press A or unscrew B and lift the brace, I'm sure that's what's locking it in.
 Well, It was sort of what you said, The post in the middle is what is actually holding the stem in. But the only way to get it to depress, is to move/remove the clip. Once I did that, I was able to depress the post in the middle, and the stem released. So, Now I've got the stem out, and trying to figure out which piece to buy to replace it. I noticed the numbers "1198" on the watch interior, And they seem to be numbers I see correlated to certain stems. Is that what I need? an 1198 stem? Here's an image to the stem I pulled out. Is there a name to this particular style of stem? Sorry for the newbie questions, I'm really good at due diligence and research, but this is like a stab in the dark finding info online for some reason.
So, this is the chart I saw on Esslinger, that had the 1198 numbers correlating to the stem. Am I way off base here?
Ok, so what I’ve found, is that this is an AV SEMAG movement ISA 1198, and does appear to use the 401-1021 stem.
can anyone confirm these findings?
Sorry I didn't reply earlier, have just checked back this morning on the forum.
I wouldn't have been much help unfortunately, stems are a pain unless a common model of watch or movement.
Hopefully that's the right one and glad you got it removed.
Thank you "Watchweasol" and "m1ks", I appreciate the help. Parts are ordered. Hopeful that I am going to be good with the crown I ordered, as the diameter of the original was 4.3mm and I couldn't find any that exact size, so I ordered a 4.5mm one. the space for it was 4.9mm so I think I'll be OK. I will update all this once the repair is done, in case anyone is ever searching for this info, like I was.
    • I also still use my cheap first set of screwdrivers. I replaced the blades of the smallest (0.6mm) with higher quality once I had bent a few of the originals, but beyond that I have been fine. Note though that I do not work on any remotely valuable watches and most of what I deal with are in a truly terrible state, watches that have been banging around in kitchen drawers or toolboxes. So my concern for screw head slot integrity and scratches is usually not very high.  As for a loupe - you won't need anything powerful for an ST36 that is new. You don't need to do close inspection of balance pivots because they will not be worn out, and a 3x or 5x loupe is perfectly sufficient to see the oiling. I don't have any microscope or powerful magnification of any sort. I just use cheap loupes. But again this would be different if I were working with more valuable watches. And if I had equipment to burnish pivots, then I would get a microscope to check my work.
    • I've recently switched over to using a x2.5 -x3 eyeglass for disassembly and some larger part assembly. It's interesting to see how accustomed and trained your eyes become to that way of working after using a microscope for years. And pick up and work at eyelevel when possible. Personally I would stick with and learn to use regular oilers efficiently.
    • I remember playing with asbestos wire insultaion when I was a kid (remember the cool fluffy white stuff?) and I've been breathing fine dust particles in my woodworking shop for years, so I'm probably toast either way, but I don't want any of this radioactive dust anywhere near my kids.
    • Its good to understand how and why demagnetisers work. These two pieces of text explain in basic terms how ferrous metal is affected by magnetism and why they can retain some of those properties.  The cheap demagnetiser is actually a magnetiser,but is used in a way that can remove the weak magnetic properties that a steel has gained through magnetic field exposure.  As steel is drawn further away from the device, the magnetic fields around it become progressively weaker and more -irregular- . This causes the disruption of the atomic and subatomic alignments within the steel that make it magnetised. So also moving the steel  through different orientations as its pulled away could actually improve that process. I still use my first cheap set of drivers, I notice very little difference in the way of feel between them and a set of preowned Bergeon I use, blade quality is more important. Tweezers have more variables, but again they don't have to be expensive to work well. My most used tweezers are my cheapest, but then I never use any pair that I haven't modified in some way.
