Landeron 248 Movement Cleaned And Serviced By Mark
Try putting everything back together and closing the back cover. I think one of the two springs has to contact the metal casing to ground the casing. So when you press the button, it will touch the contact on circuit board and close the circuit. -
Yes, the seconds hand is the longest and goes almost to the edge of the dial. I can’t quite picture it how you do it on the rubber pad
I think what peter means oh is once he has fitted the hands and checked for alignment if them and that they dont foul, how does he then hold the movement to remove the stem in order to case up. The dial cannot be laid on a cushion or in a movement holder as the hands will get damaged. This can be quite tricky for a beginner, what i do is to stand the movement on edge on a rubber pad so it doesn't slip. Hold the top edge with one finger then my dominant hand uses 3 fingers to press the stem release and flick out the stem. See below peter, leave off the second hand as this is the longest and gets caught the most, then fit it once the stem is out. Alternatively place the movement in one of the cup style holders, i imagine this is what they are designed for. They only touch the very edge of the dial. -
Yes I understand that. What I’m asking is, after the hands have been fitted, it’s been checked that the hands do not touch etc. then I need to remove the stem to fit the movement in the case. I have the push type, I need to turn it upside down and push the setting lever post and pull the stem out. But of course the dial and hands are in place and I have a glossy dial with lume dots and I do not want to cause any damage while it’s upside down pushing on the post of the setting lever.
