7751 Moonphase Calendar Drive Wheel
Hi
The top and bottom sections of the CDW - 2555 on the 7751 Moonphase has come apart so that the little finger won't move the Day Wheel.
I was wondering what I can do to fasten them together again using my staking tool.
Also, can the Calendar Platform be taken off without removing everything. I'm thinking removing the Combined Maintaining Plate and the Date Jumper should suffice.
But I'll remove everything if necessary.
Thank you for your advice.
  • 6 months later...
    • No John, we don't want Mark to change anything, we are just scared of losing a brilliant forum and losing contact with each other.  As pointed out, this forum is full of knowledge and I for one,  consider the regulars friends. I would hate to lose contact with you and the others.   PS, this forum is really important to me.
    • one little minor problem with your chemistry experiment here which is what exactly is epilam? In other words is it an exact substance with the chemical you specify or is it a term? For instance originally it was steric acid either dissolved in some sort of solvent or it was applied by vaporizing it. Then now it's all kinds of different things the watch companies all have different ideas there's a whole bunch of patents. So is not always an exact substance.   let me snip out a image from the patent that I attached up above. Notice I highlighted something it seems to disagree with your evaluation.
    • I guess You had to try, as it would be hard to sleep without that try, but, I know the result before the experiment... As I told before, the friction will be so big that the wheel will not turn. The pivots have to be thin and polished - the bigger the number of the wheel (2th, 3gh, 4th...), the thinner the pivot. What You are trying to do is possible, but forming the new thin pivot must be done on lathe. Thus the wheel will get shorter, but can have new pivot without the drilling for normal standard repivoting. Then piece of brass can be soldered under the pivot hole in the bridge and new hole drilled in it to form the new bearing.  Well, this way is not the recommended one, not quite correct, but it is possible to do for the excersize... When I say lathe, lathe may be verry simple, someting like turns, but made of what one has in reach of his hands. If You want to try, I will try to guide
    • yes by all means let's gather up our weapons tar feathers find the nearest tree in case Mark is not agreeable to our terms on our demands and storm his Castle. I don't quite understand what you're trying to do here? In other words you want Mark to somehow guarantee that the group will live on forever no matter what? You want Mark to somehow change his business model of what is trying to do or should we just take the group away from him? oh and is quite possible that Mark never realized that his discussion group would take on a life of its own. That the members of the group would like to continue on forever.
    • I'm not sentimental, I see it this way.  I inherit something I  don't like, I could sell it, buy something I do like and remember the person with the new item.  For example, I  inherit a watch ( I haven't), I don't like it, I  buy a watch I do like, every time I look at the watch, I think of the person.
