HI All
I have been messing around with cheap watch movements and have been pretty successful in rebuilding them. I Had lost my Crown cover on my Cartier and finally after over a year found one ..The watch looked pretty dirty so I decided just to remove some of the gunk, so I removed the movement. While  replacing the stem I was having a hard time but finally got it in . I can rotate the hands but I can not quick set the date. The date will set by rotating hands. I am pretty sure I can handle it but I am a little nervous  as this watch cost more than my first car. Before I dig into it I would like to know possible causes.
Thank You
Anthony
Well because I am an impatient A%^ .I could not wait for a reply so I when ahead and .Fixed it. Some how the key less work got screwed up Anyway I lost the  minute train bridge screw anyone know where to find one? Part 5462 10.062.01  Screw for minute train bridge
Ok I found a suitable screw in my rejects pile.  ...But Movement not fixed... I get it to work but when I remove stem to insert movement into case I can't get the stem back in properly. I take it apart again and it works find until I remove stem ..Am I removing and installing stem properly. I push down on the pin to both remove and install stem. What the hell am I  doing wrong?
Is the crown or stem fouling on the case, stem tube or some other obstruction, and stopping the stem/keyless work from returning to the running position, leaving it sort of half in and half out? I've seen a build up of gunk inside the crown causing unreliable action of the crown. is there any crown, or crown stem gasket that might be misplaced, swollen or gone hard over time?
Did you clean and lubricate the keyless works?
Show us some close up pictures please.
Edited by AndyHull
Hi AndyHull
It was user error ...I did not realize you are suppose to remove the stem in the time set position ...I rebuilt key less and all is fine now .
Thank you for your reply.
Anthony
PS I purchased a clone 2892 to practice on before I rip The Cartier apart. If I don't destroy it I'll use it for another watch build.
I haven't  had any problems with other movements concerning removing the stem...But in general is it best to remove while in setting position or does it differ from movement to movement.
For what its worth ..I think I answered my own question .. When removing stem on 6498 movement, stem should be in the winding position. Otherwise the winding pinion falls out. So I guess position of stem when removing it depends on movement
    • I love my brass tweezers and use them for 90% of my work. I like that brass is soft and does not scratch parts and it seems to grip parts better than stainless steel. And brass is also non-magnetic, which really helps when working on quartz movements. However, brass is a little too weak for jobs like pulling back yoke springs. So I thought of upgrading to bronze. But I can't seem to find curved bronze tweezers. And Cousins price for a pair of Bergeon straight bronze tweezers is around £45. A couple of months back I had the idea of swapping out the carbon fibre tips of my tweezers and putting in bronze tips. And that is what I did. I got a piece of 2.0mm bronze sheet from AliExpress and cut out 2 curved tips and replaced the carbon fibre tips. I'll probably thin down the tip further gradually to a point where it still has strength to draw back thick yoke springs.
    • Ah, well that's a relief, though the parts document does list a 1520 which is a coupling clutch. This threw me for a while (it's a quiet day in the office) until I realised I couldn't see a listing for the reverser wheels. So, we're back to the mainspring should slip in the barrel. It can really only be one of three things (that I'm aware of) mainspring 'coned' and pressing slightly on the lid the kink, close to the  end of the spring, which puts a sort of a self lock grip on the spring and may not allow the spring to release enough there to allow slipping quantity of lubrication, either not enough, or too little Two of those require new mainsprings, which aren't readily available, though I may post a query about alternative mainspring sizes. The third, will more grease or less be required? The word breaking in breaking grease suggests more means more breaking?
    • The idler gear I'm referring too is the one between the 2 barrel wheels. These movements just rely on the spring slipping to prevent over winding.
    • Not sure how useful this might be, but a while back I bought some bamboo tweezers (multipack with a ridiculous amount of them in) and have been using them in place of pegwood. Seems to be working just fine
    • Ah, well there is the rub. I ordered a post and oscillating weight, but clicked on the wrong thing when adding the weight to the basket adding an automatic bridge. Ordered a weight, and it's somewhere in the ether after our customs and excise folks rejected it because of the documentation.  Yes, both springs inserted the same. "Is the idler gear ok", and here's why I posted to the newbie area: So, reading between the lines, and again correct me if I'm wrong here, the automatic winding mechanism will have an ideler gear, along with the reverse wheels, that prevents over-winding? There is nothing (that I'm aware of) between the crown pinion, crown wheel, and the ratchet wheels to prevent over-winding other than the mainsprings slipping in the barrels.  This is only the second automatic I've worked on. The other, a Vostok, had a very obvious mechanism.  I shall look at the automatic winding mechanism in a bit more detail when I've a bit more time. At the moment I'm taking a glance here now and then when work is dragging 😉 As ever, thank you for your help. Always appreciated.
